Electric Socket By Shower - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-05-2012, 08:21 AM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Always remember, EGC trumps gfci protection everytime!
Old 06-05-2012, 08:24 AM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't want to get into a debate over why it is required, but I think you are off on your thinking.
Look at where GFI protection is mandated...where water is likely to be...near sinks, in a basement, in a bathroom, counter tops, outside.
Old 06-05-2012, 08:29 AM   #18
E2 Electrician
Yeah silly, and all receptacles too... Because the ground pin can be compromised on the appliance they are using. Think about it, if an appliance has a working EGC then there can never be a shock hazard because the OCP will trip. Now, we plug in a faulty tool with a ground pin compromised, the OCP device won't trip and we have a serious hazzard. Make sense?
Old 06-05-2012, 08:52 AM   #19
k_buz's Avatar
Nope, a perfect example is a bad underground. GFI protection isn't required for all undergrounds, and I have been to numerous service calls where the hot was damaged and didn't trip the breaker, but if the wire was GFI protected the GFI would trip because it would sense the imbalance.
Old 06-05-2012, 11:22 AM   #20
E2 Electrician
So you think every underground service should be gfci protected?
Take this example and logically give me an answer.... If I hard wire a piece of equipment in a gfci located area, I can omit the gfci protection. But if I choose to use a plug and receptacle, now it must have gfci protection, this only applies to 15 and 20 amp circuits mind you.
Old 06-05-2012, 12:31 PM   #21
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
K buz,
I love your new avatar
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
k_buz (06-05-2012)
Pros Cons All Electric Home??? Property Virgin Electrical 29 03-06-2013 06:33 AM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 01:00 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
