Electric Socket By Shower - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 06:47 PM   #1
Rewards Points: 12
Electric socket by shower
How far from a shower door should I go before putting in electric socket? I know I should use gcfi correct.How about my exhaust fan it says ok for shower should it be above the shower?It has a light also .
ndmick is offline   Reply With Quote
Old 06-04-2012, 06:53 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Anywhere outside of the tub perimeter is fine. GFCI required.
GFCI is only required IF the manufacture requires it... so read the manual for this answer.
Old 06-04-2012, 06:55 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
You can place a fan and/or light directly above the shower if it is GFCI protected.
Coastal South Carolina
Old 06-04-2012, 06:58 PM   #4
E2 Electrician
It only needs to be GFCI protected if the manufacture requires it.
Old 06-04-2012, 07:18 PM   #5
Rewards Points: 6,652
Actually local codes can trump what you stated.
Old 06-04-2012, 07:34 PM   #6
Rewards Points: 12
Then should I wire the bath vent and light after a GCFI socket or run a separate line to it?Or use a GCFI breaker?
Old 06-04-2012, 07:36 PM   #7
E2 Electrician
Of course, but I don't have that amendment. And its a ridiculous amendment to begin with.
Old 06-04-2012, 07:38 PM   #8
E2 Electrician
Using a GFCI will be cheaper, plus you can test/reset the GFCI if you install it in the bathroom with ease.
Old 06-04-2012, 10:10 PM   #9
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 60
Regardless of what code or manufacturer says I think it's a smart idea to use a GFCI regardless. Then again I have a light above my shower that's not (it's sealed). For some reason the GFCI outlet in the same switch box does not like the timer switch I used so it trips. In a new construction situation I would definitely do it.
Red Squirrel is online now   Reply With Quote
Old 06-04-2012, 10:14 PM   #10
E2 Electrician
I guess I just look at it as being pointless, so I don't see the need for it.... With that said, it certainly won't hurt anything either.
Old 06-04-2012, 11:05 PM   #11
Missouri Bound's Avatar
Why is it pointless? GFCI's are required in damp or wet locations, right?
Do you want it your way or the right way?
Old 06-04-2012, 11:22 PM   #12
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Most bathfans I install (Broan/Nutone) have exposed receptacles under the trim, since this is a damp location, those would need the protection along with the motor.
Old 06-05-2012, 07:02 AM   #13
E2 Electrician
Ugh... really? Where in the NEC did you find that requirement? With that line of thinking, you wouldn't be able to install a fan in a shower area at all because of 406.8(C).
Old 06-05-2012, 07:43 AM   #14
k_buz's Avatar
Yeah, I pulled that one from my butt, but think about it...
The difference between a recessed light over a tub and a fan over the tub is the fact that shower trims are sealed so no moisture can get inside the can. Obviously fans are designed so air is allowed to get inside the trim.
You are correct that the NEC doesn't require GFI protection for exhaust fans over a shower/tub, but I just looked thru 5 Broan fans and all of them require GFI proyection over a tub or shower.
The Following User Says Thank You to k_buz For This Useful Post:
gregzoll (06-05-2012)
Old 06-05-2012, 08:18 AM   #15
E2 Electrician
I think you're missin the point why gfci protection is required in general, it has nothing to do with moisture, in an application where the egc can be compromised, such as a corded tool and the ground pin being broken off, then gfci is required as a second means of protection, but when you have an exhaust fan or a recessed light where the EGC is not going to be compromised then why require it? Look at it this way, the fixture can't possibly be energized with the EGC in place, so no shock hazard is ever going to exist.. Hence the gfci protection is just not needed... Also, how many post lights or outdoor fixtures have you installed with gfci protection?
Pros Cons All Electric Home??? Property Virgin Electrical 31 01-20-2017 08:58 PM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 01:00 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
