Electric Socket In The Same Housing As A Switch?? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 09:44 PM   #1
Rewards Points: 198
electric socket in the same housing as a switch??
i need to add an outlet and want to avoid cutting through the dry wall for electric work. however i've just noted that the current housing actually has filler plate in it that doesn't have anything. so is it against code to install an outlet in the same housing? tx
vote4Pedro is offline   Reply With Quote
Old 11-13-2011, 10:00 PM   #2
Can you post a photo?
Old 11-14-2011, 09:41 PM   #3
Rewards Points: 198
it's just one of these housings with 2 light switches.
currently there's a filler plate in the left mot position so i'm thinking about putting in a socket..
edit: this socket will most likely be used a phone charging station on top of a dry bar.
Old 11-14-2011, 09:56 PM   #4
iminaquagmire's Avatar
Rewards Points: 338
There would be nothing wrong with it so long as it didn't violate box fill or GFCI placement rules.
iminaquagmire is offline   Reply With Quote
Old 11-14-2011, 10:32 PM   #5
Usually, a socket refers to the place where you screw a light bulb into. Where you plug a device in, is called a receptacle.
Thats why I asked for a photo.
Old 11-14-2011, 10:49 PM   #6
Rewards Points: 198
tx for the clear up.
on a side note, if i'm looking to install a sink near that area down the line, will a GFCI outlet be required? if so, will i be looking at a separate receptacle down the line anyhow?
Old 11-15-2011, 09:20 AM   #7
Pass and Seymore make many different variations of switches. A double, single gang switch is available. I would suggest that you would install a GFCI receptacle in the blank position and a double switch for the lights.
Old 11-15-2011, 11:51 AM   #8
Rewards Points: 198
when you say double switch, do you mean something like
if so, i can't really do that as one of the switch is a 3 way and the other is one of those fancy dimming ones with a remote. my concern is that the switch is too close to the outlet so it's more prone to electric shocks with loose plugs.
Old 11-15-2011, 12:46 PM   #9
Yes! Thats what I had in mind. In your scenerio, it looks like you will have to install and additional box (or change to a 3 gang box) for the GFCI.
Old 11-15-2011, 12:52 PM   #10
Rewards Points: 198
sorry for the confusion. the one i have isn't it a 3 gang box already?? is there a special one for GFCI?
currently it can house 3 sockets/switches and 2 are used for switches. the one open "gang"?? is covered by a fake switch plate which i'm planning on removing. does that sound about right?
Old 11-15-2011, 12:58 PM   #11
The photo that you posted is a 3 gang box. At first glance it appeared to me to be a 2 gang box. If yours is a 3 gang box, you will be fine.
Old 11-15-2011, 02:10 PM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
You need to verify if there is a neutral in the box. With only 2 switches they may be switch loops ans you can not add a receptacle without rewiring.
Coastal South Carolina
Old 11-16-2011, 09:58 AM   #13
Rewards Points: 198
thanks. will install in the open slot.
Electric Time Switch David Cosner Electrical 2 03-30-2011 11:15 AM
lamp socket TimPa Electrical 7 02-23-2011 04:30 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
