Electric Smoke Alarms - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 10:37 PM   #1
I am rewiring a new house I bought, Where does every one prefer to put their smoke alarms? On the ceiling or on the wall?
POWER STROKE is offline   Reply With Quote
Old 09-16-2012, 10:41 PM   #2
Rewards Points: 13,274
On the ceiling.
Old 09-16-2012, 10:56 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
When in doubt....follow those written instructions included in the box.
But as Joe says....ceiling is better....but....there are constraints as to how close you can be to a wall....
So....read the instructions....I know it goes against the man code....but sometimes you have to do it....
ddawg16 is online now   Reply With Quote
Old 09-17-2012, 01:55 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Most case ceiling but this part for smoke alarm placement this you will have to read the manufacter installment sheet for this and by the way the specfic rules about smoke alarm generally will be found in IRC ( International Resdential Code ) plus there will be your state / local addtional code requirment it may show up.
But try not to put it near the bathroom or kitchens that the two are they will trip by cooking smoke or steam from the shower / bathtub will trip them.
Merci,
Marc
Old 09-17-2012, 08:48 AM   #5
custom user
Rewards Points: 150
Also, try to avoid placing one near an air supply or return duct. Particulates in the air could set it off.
JasperST is offline   Reply With Quote
Old 09-17-2012, 09:52 AM   #6
Licensed electrician
Rewards Points: 1,258
The alarms will be more effective when ceiling mounted as smoke rises and hits the ceiling first. It would need to build down to hit a wall mounted alarm.
You need to be 3 foot away from a supply or return duct or ceiling fan.
Old 09-17-2012, 12:19 PM   #7
Mine will be hung on the wall, simply because thats where the electrical boxes are installed. If you are redoing wiring anyway, id say the ceiling
firsttimeremode is offline   Reply With Quote
Old 09-17-2012, 02:32 PM   #8
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Ceiling and in accordance with the manufacturuers installation instructions.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-17-2012, 08:46 PM   #9
thanks every one for your help and replies
Kidde Smoke Alarms FALSE alarms DSmith1 Electrical 11 12-03-2015 12:38 AM
Wiring for residential smoke alarms under 2008 NEC jeffers Electrical 13 05-13-2010 10:51 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
AC Smoke alarms - Nuisance Alarms jamiedolan General DIY Discussions 8 10-27-2008 08:56 AM
12 Smoke Alarms sootybuttercup Electrical 8 09-19-2006 09:06 PM
