Electric Smoke Alarm Sounding - No Reason - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 08:53 AM   #1
electric smoke alarm sounding - no reason
House 24 yrs happened before old replaced one about 5 yres ago it started again. I vacuumed them but no luck I shut electric off to them but some receptacles are connected. Help I am a widow!
pucci is offline   Reply With Quote
Old 12-17-2011, 09:03 AM   #2
the Musigician
DangerMouse's Avatar
Your post is difficult to decipher, but I'm assuming you have hard-wired smoke detectors and one or more is having a problem and setting them off? Or is one of them simply "chirping"? (low battery)
If they are all going off for no reason, they COULD simply be dirty and need a more thorough cleaning, or if too old, replacing them might be the best way to go. You may even be able to find an organization near you that will give them to you for free, or very cheap if cost is a factor. Check with your local fire department.
DM
Recessed Smoke Detector / Fire Alarm / Other Names for Things that Beep Around Fire Fox Electrical 12 07-26-2010 03:42 PM
Wiring for residential smoke alarms under 2008 NEC jeffers Electrical 13 05-13-2010 10:51 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
smoke detectors going off for no reason? arichard21 Electrical 18 04-20-2008 11:37 PM
