Electric For Shed - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 07:14 PM   #16
Thank you for clearing that up.
bbddt is offline   Reply With Quote
Old 04-29-2011, 09:06 PM   #17
Hey guys thank you for the responses. I have one more question. I if use a sub panel (say 40 amp) can i run 2 hots, 1 neutral, because i think that is all that will fit in the 1/2 conduit i have, and then just ground the panel with a grounding pole. so no ground coming from main panel just from grounding pole i will have to install near shed. is that possible or does ground have to come from main panel. Thank you again
Old 04-30-2011, 08:38 AM   #18
Electrician
SD515's Avatar
Rewards Points: 504
Ground wire will have to come from the main panel.
Kyle
Old 04-30-2011, 10:47 AM   #19
Just call me Andrew
Rewards Points: 1,020
Ground wire to a ground rod is for lightning strikes.
Ground wire to panel is for ground faults.
Two completely different things
Andrew
secutanudu is offline   Reply With Quote
Old 05-29-2011, 02:00 PM   #20
sub panel problems
having problems with new sub panel in shed. I ran 4 #10 from a 30 amp double pole breaker in main panel to a sub panel in shed. I have two 15 amp breakers and one 20 amp in new panel. one 15 amp is for 4 outlets around deck the other is for two lights and two outlets in shed. the 20 amp is for the pool filter. i hooked everything up and breaker in house blew twice so i turned off two of the breakers(filter and deck) and tried only one 15 amp (for shed) i turned it on and thought it was good but when i turned off switch the breaker blew again any ideas please help
jvap42 is offline   Reply With Quote
Old 05-29-2011, 02:30 PM   #21
Rewards Points: 1,016
Eaiest, cheapest, and should provide for the need as described is the MWBC that has been proposed. This would provide two 20a circuits.
Old 05-30-2011, 12:48 AM   #22
Rewards Points: 506
I didn't read the whole thread, but I think this is a new project (not OP).
Old 05-30-2011, 12:54 AM   #23
Rewards Points: 506
Was anything plugged into any of the outlets when it blew?
And when you say breaker in the house blew, was it the 30amp, or the Main?
Do you have a disconnect in the subpanel? If so, what's the rating?
I'm guessing that you've miswired something, because with the pool pump OFF, I wouldn't think there's that much current draw to trip a 30a.
That said, I'm leaning toward the idea that the 30 amp in the house (and #10 wire) may be too small for everything when the pool pump is brought into the equation.
What is the rated Current draw on that pump, anyway?
Old 05-30-2011, 01:03 AM   #24
Scared Electrician
Saturday Cowboy's Avatar
jvap42 please start a new thread for new topic.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
sirsparksalot (05-30-2011)
Old 05-31-2011, 09:40 AM   #25
Hey guys thanks for response but YES electric 101 I did not pass so anyone reading this and is just a do it yourselfer listen to me you do not connect a hot and a neutral to a switch!!!! yeah for you who know you could laugh at me now i had hot and neutral to switch so when i turned it on it blew. had a friend come over and he almost fell on floor in laughter when he saw that. well job is complete and the kids went swimming yesterday thanks to everyone for your input.
Old 05-31-2011, 10:49 AM   #26
Rewards Points: 1,418
deleted
Cost-Benefit for electric vs heat pump, do my calculations look sound? chazman113 HVAC 13 08-13-2010 04:37 PM
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 10:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
