04-27-2011, 05:05 PM
#1
electric for shed
Need Help
I have been reading alot on this subject so my question is this.... I buried underground conduit 5 years ago when i built shed but not really knowing what i was doing i used 1/2 conduit so now how can i run electric there from my main panel. everyone says use a sub panel but i dont think i can through 1/2 conduit because of size of wire needed. Is there any way to do this? I think i really messed up by using 1/2 but i had no idea any suggestions. Thank You
04-27-2011, 05:30 PM
#2
Licensed electrician
electric for shed
You can still add a subpanel in the outbuilding. The size of the conduit will severely restrict the circuit size that can be taken out there tho.
04-27-2011, 06:23 PM
#3
electric for shed
1). Dig it up, and install 2"
2). Run arial service
what is the 5-year-old conduit serving now?
04-27-2011, 07:33 PM
#4
Just call me Andrew
electric for shed
Doesn't sound like it's serving anything....
If you just want lights and basic (120v) outlets in the shed, you should be fine and not need a subanel.....what is it you want to use in the shed?
Is it PVC conduit? SCH 40? SCH 80?
How long is the run? Not having to account for voltage drop (long run) will help.
Assuming the run isn't too long (less than 125 fee or so), you could get away with either:
1 x 30A 120/240v subpanel (4 #10 THWN wires in a multi-wire branch circuit)
or
2 x 20A 120v circuits (4 #12 wires...2 hots, neutral, ground)
Of course, this all depends on how easy it will be to pull wire through your conduit (number of bends, etc).
I'd opt for the subpanel.
For reference:
Raceway fill calculator:
http://www.electrician2.com/calculat...alculator.html
Voltage drop calculator:
http://www.csgnetwork.com/voltagedropcalc.html
Andrew
04-27-2011, 08:01 PM
#5
electric for shed
run is only 50ft I have a pool which i never thought i would have so electric would be for pool filter, gas heater for pool, 1 light in shed, maybe 2 outlets in shed (no power tools), n maybe couple outlets on deck for pool. only bends in conduit is 90 where it comes out of ground near house and shed otherwise its straight. can i run a 40 amp out there and do sub panel and do that?
04-27-2011, 08:03 PM
#6
electric for shed
not sure what sch 40 or 80 is and even if i did i wouldnt know what kind of conduit i used sorry. just know its grey and is used for underground
04-27-2011, 08:05 PM
#7
electric for shed
not servicing anything I just ran it in case i needed it. so i thought ahead there but never thought of running anything bigger than 1/2.
04-27-2011, 08:15 PM
#8
electric for shed
The grey makes it sound like PVC conduit.
Schedule 40 and 80 refer to the thickness of the conduit wall. Sch 80 is thicker than Sch 40.
You do not have enough space in a 1/2" conduit to run #8s for a subpanel. You only have room for 4 #12's.
04-27-2011, 08:31 PM
#9
electric for shed
yes it PVC conduit not sure of sch 40/80 so if i run 4 #12s thats just one circuit at the main panel? and that will cover what i need?
04-28-2011, 12:02 AM
#10
Just call me Andrew
electric for shed
you will have 2 x 20-amp circuits if you run 4 #12 THWN (red, black, white, green). You would install a double-pole 20A breaker, red and black go to the breaker, white & ground go to the bus bars. The neutral will be shared among your two circuits.
THis is called a multiwire branch circuit (MWBC), and can only be safely done via a double-pole breaker that spans across both hot buses in your panel.
Andrew
04-28-2011, 03:12 AM
#11
electric for shed
How deep is the conduit buried?
____________
Vince
04-28-2011, 05:30 AM
#12
electric for shed
Run another 2" conduit and use the ½" conduit for phone line. 60 amp min.
04-28-2011, 09:08 AM
#13
electric for shed
If you run the 10 gauge wires for 2x30 amps, you will still need the subpanel. Here you can have four 20 amp breakers, two on each side of the line.
If you run new conduit, it is suggested you plan for at least 2x60 amps with 6 gauge wires (aka a 60 amp 120/240 volt circuit).
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
04-28-2011, 01:22 PM
#14
electric for shed
im not looking to run new conduit i ran what i have before i had grass and dont want to re dig.. the conduit is bout 24-30 inches deep. alittle confused on the "2" 20amp circuits? if i run 4 #12 to shed wouldnt black and red go to 20 amp circuit in main and white n green go to bus bar now isnt that 1 20 amp circuit? can someone clear this up please. If i want "2" 20 amp wouldnt i have to run 8 #12..4 for each?
04-28-2011, 04:03 PM
#15
Just call me Andrew
electric for shed
4 wires on a double-pole breaker would give you (2) 120v circuits. Each circuit has one hot (red for one, black for the other). The circuits would share a neutral (white) and ground (green).
Andrew
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
