Electric Range, Not Keeping Up Temperature - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 01:29 PM   #1
electric range, not keeping up temperature
When trying to use the broil option on my range, the top element overheated (like a lightbulb) and now it appears as though the element has a burnt/damaged spot on it. The top element will not glow now when requested. Since then, the whole oven has been behaving strangly. When using the lower element for baking the oven heats to the requested temperature. The display reads the desired temperature but it is not accurate. If I request 350 F, the oven warms up to this temperatuer (which appears accurate) and then starts to cool off with the logic still believing it is at 350 F. I can sometimes hear the relay in there clicking away far more frequently than one would expect for the heat cycle. I should note that the "preheat" stage is indicated by a little red light which moves to the "heat" stage after preheated is satisfied. Could the burnt out top element have caused some sort of hardware problem or is this likely a logic control issue? I feel the temperature sensor must work as to allow the preheat stage to complete. I have repaired the control board in furnaces before (and they are easy to buy) but I am guessing the complexity of the board in an oven is far more demanding. Do people usually just replace the range if the control board is bad? The range is a few years old.
thanks a lot
mrtmills is offline   Reply With Quote
Old 02-23-2009, 02:19 PM   #2
the Musigician
DangerMouse's Avatar
if it were me, i'd replace the element first, and see what happens from there.
Old 02-23-2009, 04:31 PM   #3
Probably it failed to an open circuit but check it with an ohmmeter. (240)/5kW = ~12 ohms.
Also check that there is infinite resistance from the heater element to the tube that surrounds the ceramic center of the element.
Hopefully your oven is hardy enough that a single failed heating element does not cause failures that cascade upstream.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
install Electric range top JBH Electrical 7 01-18-2009 05:32 PM
how to stop condensation on windows? cake General DIY Discussions 7 11-22-2008 12:12 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Electric Range Wiring manhattan42 Electrical 11 07-05-2006 05:03 PM
