Electric Range In Dryer Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 02:15 PM   #1
Electric range in dryer outlet
I just got a new electric range and the installers said they couldn't plug it in because the outlet is for a dryer. Both the outlet and plug are four prong but the outlet has a " L " shaped prong at the bottom. The installers left the old cord ( also 4 prong) off the old stove. Should I use the old cord on the new stove since it goes in the outlet or should I try to get the outlet changed? If I need to change the outlet does that mean re-wiring?
Greenlevel is offline   Reply With Quote
Old 02-03-2011, 02:22 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
The receptacle needs to be changed.
You need to get a 4 wire stove receptacle.
The Following User Says Thank You to jbfan For This Useful Post:
Greenlevel (02-03-2011)
Old 02-03-2011, 02:39 PM   #3
Yep - replace the receptacle with the proper one...don't use the old cord. I actually ran into the reverse of what you have just recently. Purchased a new electric clothes dryer, and the installers informed me the receptacle the old one had been connected to was for a stove. About $10 for a new receptacle at the Big Box store and 10 minutes of work though and I was back in business. If you decided to change out the receptacle yourself, make sure you turn the breaker off first!!
H8Mondays is offline   Reply With Quote
The Following User Says Thank You to H8Mondays For This Useful Post:
Old 02-03-2011, 02:56 PM   #4
Thank You
Thank you both. So, since I know nothing about electricity let me make sure I have it right. I need to change the wall outlet, right? There is no need to re-wire anything to / from the breaker box. Do I need to check the fuse in the breaker for anything. I plan to ask my cousin to do this, but I need to know what to ask and what is the right thing to do.
Old 02-03-2011, 03:23 PM   #5
Yes, the wall outlet needs to be changed. However, both the circuit breaker and wire size really depends on the nameplate rating of your new range. Check either in the manual or on the range itself for this rating and then compare it to what you currently have. If they match, you shouldn't have to make any changes here. If they don't however, then you may be looking at upgrading both of those components along with the wall outlet.
I believe standard ranges require a 40A double-pole breaker along with 8-3/w ground wire, but there could be some variation, so double-check what your new unit actually calls for.
Old 02-03-2011, 05:20 PM   #6
Don't set the oven any higher than 250 to dry clothes.
Hourglass52 is offline   Reply With Quote
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Electric dryer fire prevention Know It ALL Safety 2 12-08-2010 08:53 AM
soggy outlet pipe for dryer? darsunt Appliances 5 08-04-2010 12:28 PM
New electric dryer is blowing breaker! minameismud Electrical 7 09-14-2008 10:45 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
