Electric Radiant Heating - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 08:25 AM   #1
rditz's Avatar
electric radiant heating
wanted an opinion on the use of electrical radiant heating.
is it efficient? is it expensive to operate? is it expensive to buy??
I will be renovating a couple of bathrooms and one is on the main floor over a crawl space of a farm house. a very cold room. It is also one of the last heat runs from the furnace and when it comes on, I get cold air for a while until the entire heat duct has warmed up. my thought is, if I could close that off and use the floor heating to make the room comfortable, it would solve the cold problem.
thanks
rod
rditz is offline   Reply With Quote
Old 02-02-2011, 09:21 AM   #2
Rewards Points: 1,514
I know you can buy it but I don't know how much it costs to buy and install. I thought I saw one such display at Home Depot.
It is expensive to run, just like electric baseboard heaters.
It does not heat up particularly fast.
Do not try to cobble together parts not originally intended for radiant heating; that could cause a fire hazard.
Old 02-02-2011, 09:23 AM   #3
rditz's Avatar
thanks...
Old 02-02-2011, 09:27 AM   #4
I know you
(added later: The minimum of 10 characters that must remain when a duplicate or other p post is deleted)
Old 02-02-2011, 09:31 AM   #5
rditz's Avatar
you know me??
Allan,
please, tell me where you think you know me from... always cool to meet people from the past.
rod
Old 02-02-2011, 10:35 AM   #6
Electrical Supplier
Rewards Points: 150
Radiant heating is not designed to HEAT a room. Its a luxury to keep your toes warm........
It is relatively expensive (about 200 bucks for 10 sq feet) and uses about 2 amps per 10 sq feet.............
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 02-03-2011, 04:48 AM   #7
dSilanskas's Avatar
I've installed it many times. More and more people are installing it. Yes it does cost alot to buy but it is very efficient and IT IS cheaper to run than electric baseboard heat.
dSilanskas is offline   Reply With Quote
Old 02-03-2011, 07:44 AM   #8
rditz's Avatar
would you have an estimated $/sqft?? and what is your opinion on operating costs?? is it worth it?? is it only a complimentary heating product, or would it work to keep a cold bathroom (with the door open) up to temp??
as I mentioned, I am planning a reno in a bathroom in an old farm house that the the crawl space below makes the tile floor real cold.
thanks
rod
Old 02-03-2011, 07:50 AM   #9
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Originally Posted by rditz View Post
Allan,
rod
..........he doesn't know you.....that was an attempt at an edit......
tcleve4911 is offline   Reply With Quote
Old 02-03-2011, 07:52 AM   #10
rditz's Avatar
yes, I found that out from him later in a PM.
thanks
rod
Electric Mat Radiant Floor Heating Question ryan5068 Flooring 14 09-03-2010 10:37 AM
Considering Radiant Heating acerunner Remodeling 4 07-03-2010 02:17 AM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 01:04 PM
Suntouch electric radiant floor heating reg Jim Anderson Electrical 3 10-25-2009 08:13 AM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 07:27 PM
