Electric Raceway - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2013, 10:42 PM   #1
electric raceway
I had electric service installed in my log cabin (permitted and approved). The well pump and several basic circuits are already operational. I now need to run branch circuits from the breaker panel (which is close to the main beam in the basement) for service in the basement, first floor and the loft. Romex was installed in the logs for the loft and the wall switches on the first floor. I would prefer to run the branch wiring along the beam instead of running through all the joists. I would then run each cable along the appropriate joist for each service point.
Could I use a raceway instead of stapling each cable to the main wood beam?
craighuber48 is offline   Reply With Quote
Old 03-02-2013, 07:09 AM   #2
DIY staff
Rewards Points: 7,174
Could you use 1/2" or 3/4" EMT conduit? That would be neat and safe from damage in the exposed basement? Also would allow you to add future circuits easily-----
I'm not an electrician-----but have experience in these things------
Old 03-02-2013, 10:59 AM   #3
Rewards Points: 204
If you want to see this cable then it sounds fine. I would personally find a way to do it so the cable is not visible.
If the cable is installed where it would be subject to physical damage, that would be a violation in itself.
I would think hard on this. Think before you do anything.
Tags
raceway electrical cable
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 05:23 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
