Old 01-19-2013, 05:57 PM   #1
Electric proximity to plumbing NEC 2011
Under NEC 2011 what restrictions are there on how wiring can be placed in relation to plumbing?
I want to put romex in a celing/floor joist cavity that already has copper pipe and PVC drain. Can I do this or must I use an adjacent joist cavity? How about a light box/fixture in that same joist cavity? When pulling romex through a wall (through studs) is there any restriction on where I can put the romex? Can it go below plumbing feed pipes? Should it be above them? Should I try to route it in an entirely different wall than the plumbing?
Dunk is offline   Reply With Quote
Old 01-19-2013, 06:12 PM   #2
Master Electrician
Only restrictions apply to above the loadcenter.
brric is offline   Reply With Quote
Gas vs. electric heating (comparing MCF to kWh) fetzer85 Off Topic 2 07-29-2010 04:18 PM
Tankless gas vs. electric water heater- pros/cons gbwillner Plumbing 6 07-07-2010 12:38 PM
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 10:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 09:34 AM
