Electric To Pole Barn - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 02:07 PM   #1
Electric to pole barn
I want to run electric underground to barn from 20 amp breaker in the panel in the house. About 190 feet total run. What wire should I use?
ddailey is offline   Reply With Quote
Old 04-22-2013, 02:14 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 256
What is the expected load at the barn?
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
stickboy1375 (04-22-2013)
Old 04-22-2013, 05:36 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
20 amps for a pole barn? Not saying that's all you need, but hell, if i'm wasting my time digging a trench, i'm installing a 100 amp line minimum....
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
jbfan (04-22-2013), mpoulton (04-24-2013)
Old 04-22-2013, 06:36 PM   #4
load is 4 florescent light fixtures and recptacles for occasional use of table saw, drop light, cutoff saw use, battery charger, etc.
Old 04-22-2013, 06:42 PM   #5
E2 Electrician
Is money an option? Because I would at minimum, install a 2" PVC conduit from the house to the barn, if money is an issue, I would pull # 10 THWN conductors to the barn, (2) hots (1) neutral (1) ground.... that would be BARE minimum... but leave you with future possibilities if you find out you need to increase your electrical needs. If money really isn't an issue, I would go for the 100 amp panel right from the start.
frenchelectrican (04-23-2013), oh'mike (04-22-2013)
Old 04-23-2013, 07:52 AM   #6
Thanks.
Money is a consideration. I'm thinking a shallow trench 6-8" deep, without conduit.
Is #10 large enough? When I run the calculator at http://www.elec-toolbox.com/calculators/voltdrop.htm, using 190 feet and and 20 amp load, I get #4 wire.
Old 04-23-2013, 08:05 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Thanks.
Minimum depth is 12" for a 20 amp circuit that is GFCI protected prior to going underground.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Jim Port (04-23-2013)
Old 04-23-2013, 12:51 PM   #8
Good info. Thanks.
Old 04-23-2013, 07:35 PM   #9
E2 Electrician
Thanks.
I seriously doubt you'll have a 20 amp load, but with that said, you'll have (2) 20 amp circuits shared with one neutral, its the best way to go.
If you are not considering conduit, buy 10-3 UF cable, if you can afford any wire size bigger, I would opt for it, this way you can always install a panel later on down the road.
The Following User Says Thank You to stickboy1375 For This Useful Post:
ddailey (04-24-2013)
Old 04-23-2013, 07:53 PM   #10
Rewards Points: 6,652
Copper #8, Aluminum #6, for 240vAC, 20 Amp.
Old 04-24-2013, 06:43 PM   #11
Thanks- Sounds like a good plan.
Old 04-24-2013, 07:09 PM   #12
Semi-Pro Electro-Geek
Rewards Points: 2,904
I'll throw in another vote for conduit. Even if you only use #10 wire now, having 2" conduit in place will be a relief when you decide you want to weld out there, or run a big air compressor, or use heaters in the winter, or any of the many other things you might want to do in a pole barn that will require serious power.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
ddailey (04-25-2013)
Vapor barrier for a Pole Barn maddog1 Building & Construction 3 08-22-2012 11:18 AM
Pole barn footing question Badfish740 Building & Construction 12 08-21-2011 10:06 AM
Pole barn vs steel I beam building. Do they compare structurally? viper Building & Construction 0 05-23-2011 07:17 PM
Pole Barn Plans snateman Carpentry 1 06-17-2009 07:09 AM
pole barn ? @ span length & size lumber req.. ugabulldog Building & Construction 3 09-11-2008 02:07 PM
