Electric Panel Wiring Techniques - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 11:10 PM   #1
electric panel wiring techniques
I have a question about how wires are tied into the panel. If a neutral and a ground are tied onto the same bus, wouldn't that make them the same and make them not work as both a ground and as a neutral? I have always seen it done this way. While I know a decent amount about electricity, I don't understand how this works.
Thanks for the advice and clarification.
brokenhammer is offline   Reply With Quote
Old 11-06-2010, 06:22 AM   #2
In a main panel, neutral and ground busses are connected together, along with the earth ground electrode. Nowhere else in any system should that happen. In a sub panel, the ground buss is connected to the panel, but not to the neutral buss. The neutral buss is also isolated from the panel.
Old 11-06-2010, 06:33 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Yes, ultimately the neutral and grounds are tied to a common point. THAT is where it ends. It's what happens to them, and what their intended purpose is, once they leave the main panel that is key here.
The neutral is intended to carry circuit current back to the source.
The ground is intended to carry fault current back to the source.
These are two VERY different things.
A very odd example would be that we have wine and we have grape juice. They both come from grapes, but they are both not the same thing.
Saying that grounds and neutrals are, or do, the same thing is like saying wine and grape juice are the same thing.
Old 11-06-2010, 09:02 AM   #4
Rewards Points: 1,216
Nice clean looking panel.
COLDIRON is offline   Reply With Quote
Old 11-06-2010, 01:58 PM   #5
Chicago, IL
Michael Thomas's Avatar
Brokenhammer, see Stubbie's post (#4) at Sub panel grounding
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Wiring for electric range rgustavw Electrical 2 09-21-2010 02:18 AM
thermostat wiring for electric heater Captflx HVAC 3 03-05-2010 08:48 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 12:16 PM
