Electric Panel Enclosure Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 08:10 PM   #1
Question
Electric panel enclosure question
Hi,
I am finishing the basement. The basement contains an existing electric panel (which I am not modifying). I have built framing around it and roughed-in the wires. It passed rough-in inspection.
Now I need to build an enclosure around the panel. Technically this is not a problem since i'll build it extending the frame out about 1 to 2 inches (to account for the protrusion of the panel out or the frame). However, I don't know how close to the breaker handles themselves am I allowed to install the door? I asked the inspector and the jack a** did not answer. It looked at me as if this distance would be totally irrelevant.
Can I install the door barely touching the plastic handles? 1/4 inch? 1/2 inch? Since the door is going to be made out of wood, this could represent a fire hazard if anything happens. Wouldn't this distance be coded? Is there a minimum clearance?
Oh, btw, I live in Ontario, Canada. However, any answer / guidance would be *exceedingly* welcomed!
globus999 is offline   Reply With Quote
Old 11-23-2010, 08:19 PM   #2
I=E/R
a7ecorsair's Avatar
It sounds to like you are making a new panel cover. Is this correct?
a7ecorsair is offline   Reply With Quote
Old 11-23-2010, 08:27 PM   #3
Yes, this is correct.The existing panel has no cover.
Old 11-23-2010, 08:37 PM   #4
I=E/R
a7ecorsair's Avatar
You will have to wait until one of the Canadian electricians jumps in..
Old 11-23-2010, 08:47 PM   #5
" Euro " electrician
frenchelectrican's Avatar
I just want to make sure I am reading this correct that you need a cover to hide the whole thing like useing a cabent door to cover them up even picture frame to cover it up or.,
Metal cover which the oringal cover is missing ?
Merci.
Marc
Old 11-23-2010, 09:19 PM   #6
Merci.
Marc
Hi, yes and no. I am building something like a cabinet door to cover the entire panel up. However, the original panel is the type that does not have a door. It's just a flat panel with the plastic handles of the breakers protruding out.
Old 11-23-2010, 09:30 PM   #7
Ok.,
Now I can see where this goes anyway I know in USA generally not a issue as long you don't block the front of the load centre but Canada I think it should be simauir but just wait for Joed or other to chime in to confirm this question.
Merci.
Marc
panel clearance question MeanGene Electrical 1 09-14-2010 03:38 PM
100 AMP Panel Box Question SeniorCitizen Electrical 10 07-27-2010 03:08 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Next Question, Sub panel in detached garage... OmegaBunny Electrical 5 09-15-2008 11:37 PM
