Electric Panel Clearance - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 05:54 PM   #1
I'd like to move a water and build a closet near an electric panel. I'm somewhat confused by the 3' and 30" clearance needed in front and to the side of an electric panel. Will I be able to put the water heater where I have it on the diagram? It's not directly in front...
Also, can I put a door to the right of the electric panel?
I've attached a diagram. I hope it makes sense.
DIY2009 is offline   Reply With Quote
Old 02-10-2013, 06:08 PM   #2
MarginallyQualified
Rewards Points: 2,464
Yes.
in front of and to the sides of an electric panel.
How wide is a toilet vs how much wall space do you need to install one?
Same principle. The panel gets installed centered on 30" of wall space and then you keep the area in front of that clear for 36".
Old 02-10-2013, 06:19 PM   #3
Rewards Points: 506
Send a message via AIM to theatretch85
Actually, it is my understanding that 30" wide clearance for the panel does NOT have to centered on the panel. Given your diagram, it looks like you should be fine.
theatretch85 is offline   Reply With Quote
Old 02-10-2013, 07:09 PM   #4
Licensed electrician
Rewards Points: 1,770
The panel does not need to be centered in the 30" width. It can be anywhere in that width.
FPE Panel change out. Main Breaber to Lug TJ14u Electrical 4 01-22-2013 10:54 PM
plywood behind electric panel benleef Electrical 6 11-13-2012 06:42 PM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 10:03 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
