Electric Panel Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 12:04 AM   #1
electric panel box
i am renovating my basement and my sub panel box is on a kitchen wall , behind that wall is the shower for the bathroom. is that an issue? does it have to be relocated or can i buy a special panel box for that loaction??
thankss
handekaps is offline   Reply With Quote
Old 01-03-2010, 05:01 AM   #2
Master Electrician
JohnJ0906's Avatar
thankss
The panel faces into the kitchen, correct? If so, you are fine, no special panel box necessary.
You do need space in front of the panel 30" wide, 36" deep, and 78" high for working room. In other words, it can't be over a countertop or any other obstruction.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 01-03-2010, 05:47 AM   #3
Chicago, IL
Michael Thomas's Avatar
The location is not a problem per se, unless you have reson to suspect water penetration through the wall (corrosion at the panel, etc.).
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 01-03-2010, 09:06 AM   #4
yes it does face the kitchen and i do have all the clearances front, depts, height.....there shouldnt be any water coming through with the new bathroom being installed..hardi backer , tile and grout... the panel box itself is brand new.
thanks
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 08:34 AM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Electric panel replacement chris450 Electrical 3 05-30-2008 11:12 AM
