Electric Oven Power Requirement - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 10:39 AM   #1
Rewards Points: 16
Electric Oven power requirement
Doing another rehab and noticed the electric wall oven may have a problem. According to the specs it requires at max 27amps so I assume a 30 amp circuit would be OK. I found it is fed with a 40amp circuit on #8 wire. Is it OK to have a circuit that is at least 10 amps larger feed this oven? My concern is if for some reason something went wrong in the oven would the breaker trip before the oven is damaged or something in the oven starts smoking, other than my cooking?
Whaler Man is offline   Reply With Quote
Old 01-03-2013, 10:49 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Fine the way it is. The breaker is sized to the wiring. Change to a 30 amp breaker if you feel better.
Coastal South Carolina
Old 01-03-2013, 11:56 AM   #3
The installation instructions for ranges will specify the circuit/breaker recommended depending on the model. You may be able to find that document on the manufacturer's web site. Or call and ask the manufacturer what is recommended for that specific model.
Billy_Bob is offline   Reply With Quote
Power is dimmed, but not because of the electric company. austinomega Electrical 28 12-28-2012 07:33 PM
Can just adding new electric wiring for new outlets increase power usage? elocs Electrical 35 09-22-2011 04:37 PM
double electric oven cherylynn91406 Appliances 0 08-01-2010 04:31 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
