-   -   electric outlets no longer work (http://www.diychatroom.com/f18/electric-outlets-no-longer-work-20269/)
movistar 04-24-2008 12:25 AM
I was replacing my kitchen outlets over the counters, I successfully changed the first of three. On the second one, when I pushed it back in and heard a pop and saw sparks. The outlet had a burn mark where the hot wire was connected. Now none of the outlets work, I tried the breaker but it didn't do anything. What happened and how do I fix it?
CowboyAndy 04-24-2008 05:08 AM
Check the breaker again. Sometimes when they trip, you have to move them ALL THE WAY to the off position before switching back on. Also, is there a GFI receptical somewhere?
The question is WHY did something touch metal and sparks go flying?
BigJimmy 04-24-2008 07:57 AM
Probably touched the brass screw to the plaster ring. The bigger question would be, why on earth were you wiring the recepts hot??!
movistar 04-24-2008 11:26 AM
Thanks Andy, hit the switch again and that did the trick.
Termite 04-24-2008 11:36 AM
That's why a lot of electricians wrap the receptacles' terminals with electrical tape.
You should never work on this sort of thing with the circuit hot. Bet it made you jump!
BigJimmy 04-24-2008 12:27 PM
Understood but the OP's first line reads: "I was replacing my kitchen outlets over the counters..." If you're doing a one-for-one swap out, at some point you have to put a screw bar on the hot screw.
Couldn't agree more. Even many professional electricians that I know will avoid hot-wiring unless it's absolutely necessary.
