Electric Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2009, 03:57 PM   #1
Rewards Points: 115
Electric outlets
What's the difference in using the metal vs the plastic resepticals?
I have to change the outlet in my dinning room, and was going to replace the recetical.
Thanks in advanced!
Carloscda is offline   Reply With Quote
Old 12-17-2009, 04:06 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a metal receptacle? You are going to have to explain what you have a bit more. There are no metal receptacles as the face of it would be able to conduct electricity and as such, would be a serious hazard.
do you mean the trim plate or cover plate by chance?
Old 12-17-2009, 04:07 PM   #3
Or do you mean the box that the outlet goes into ?
Old 12-17-2009, 04:19 PM   #4
300zx's Avatar
Post
Carloscda we need more info on what you are talking about
300zx is offline   Reply With Quote
Old 12-17-2009, 04:39 PM   #5
Rewards Points: 115
My apologies..
The small box that's in the wall at the baseboard, which the outlet connects to.
Old 12-17-2009, 04:49 PM   #6
300zx's Avatar
Post
Originally Posted by Carloscda View Post
My apologies..
Is your box metal or plastic ? If metal the box needs to be grounded with a ground screw. I like the plastic boxes myself .Do you have 3 wires hot,neutral,ground?
Old 12-17-2009, 04:50 PM   #7
Metal box must be grounded to the outlet
Plastic box this is not required
Note that a lot of metal boxes have a metal bracket going across the face of the 2x4
So pulling a metal box out of a finished wall is not an easy task
Old 12-17-2009, 04:55 PM   #8
Rewards Points: 115
There are only 2 wires coming out the wall.
Right now there's no box there because the guy didn't finish the job.
I'm on my way to HD tomorrow so I was inquiring about metal or plastic?
Don't laugh, but my thinking was a spark in a metal box would just defuse vs the plastic melting?
Old 12-17-2009, 04:59 PM   #9
Do you have a ground ?
If not install a GFCI outlet & label "no ground present"
-these stickers come with the GFCI
Old 12-18-2009, 09:40 AM   #10
It sounds like you need an "old work" box. Plastic is easier to work with, and it seems to be what always goes into new homes.
pyper is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
240v electric ranges with 120v outlets Cedar City Bob Electrical 14 09-04-2009 09:16 PM
closing off outlets above electric baseboard heaters abieslas Electrical 6 11-19-2008 11:45 PM
Adding Electric outlets to bedroom with plaster walls jimmyfloyd Electrical 13 11-07-2008 03:20 PM
electric outlets no longer work movistar Electrical 5 04-24-2008 12:27 PM
