Electric Outlet / Light On Same Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 09:05 AM   #1
Electric outlet / light on same switch
Hi
I have a switch that controls a light fixture, and an outlet. What I am trying to do is keep the outlet hot and use the switch for just the light. The switch wiring is as follows, black wire pushed into plug, another black wire on screw next to plug. Red wire pushed into bottom plug with no wire on the screw. 2 white wires connected with cap.
So I took the black wire off of top screw put it with red wire now the light and outlet are always on. It appears to me that the black wire on the screw goes to both the light and outlet, and the black in the plug does nothing. I did not look at the outlets wiring itself. Does this sound like a configuration anyone has seen before, and is it possible to separate the outlet from the switch without totally rewiring the circuit?
Fieldy1123 is offline   Reply With Quote
Old 10-06-2012, 09:12 AM   #2
Resi EC
Rewards Points: 252
Originally Posted by Fieldy1123 View Post
Hi
Have you pulled the switch out, to see what on it?
Gac66610 is offline   Reply With Quote
Old 10-06-2012, 09:13 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Turn off power. Take the red wire off the receptacle. Take the two blacks off the receptacle. Splice two pigtails with the two black wires. Run one pigtail to each of the screw terminals on the receptacle. The screws you run the pigtails to should be brass not silver. Cap off the red wire with a wire nut. Turn power back on.
Old 10-06-2012, 09:18 AM   #4
Sorry fairly amatuer here. When you say receptacle do you mean switch or outlet? And can you explain the pigtails? BTW I have pulled out the switch, the wiring I described is on the switch not the outlet.
Old 10-06-2012, 09:21 AM   #5
k_buz's Avatar
Receptacle=Outlet
Switch=switch
Pigtail
Old 10-06-2012, 09:34 AM   #6
Resi EC
Rewards Points: 252
This is very well explained.( and may be the easiest way to accomplish task)
My thought was to take the red off the screw terminal of switch and move it to the other screw terminal, of course this is assuming they are not pigtailed in the switch.
Old 10-06-2012, 09:40 AM   #7
So I opened the receptacle and this is what I see top silver screw white wire. Bottom silver screw white and black wire, top brass screw red wire bottom brass white wire. In the box there is 2 black wires capped together.
Old 10-06-2012, 09:47 AM   #8
Resi EC
Rewards Points: 252
Is the receptacle half switched or both top and bottom switched?
Old 10-06-2012, 09:49 AM   #9
Both top and bottom switched
Old 10-06-2012, 09:53 AM   #10
Resi EC
Rewards Points: 252
Just re-read your OP, I missed you saying the switch and didn't register what wires were moved.(sorry)
Try moving the other black wire on the switch.
That should provide you with requested results.
Old 10-06-2012, 10:02 AM   #11
Tried switching the other black wire. Made no change outlet still switched with light.
Old 10-06-2012, 10:06 AM   #12
Resi EC
Rewards Points: 252
Can you attach pictures of receptacle and switch?
Maybe the wiring at the light fixture as well.
Old 10-06-2012, 10:27 AM   #13
Nope but I can email them to you. I'm on my iPhone it won't let me attach photos.
Old 10-06-2012, 10:53 AM   #14
Master Electrician
When he says plug he's talking about a backstab connection. The red is the always hot at the switch. Find the black that controls the plug(receptacle). Backstab connections are terrible so take the red wire at the switch and the black wire at the switch that travels to the receptacle and wirenut them together. Pigtail out to the terminal screw on the switch. The other black which is the one that travels to the light goes on the other terminal screw of the switch. Leave receptacle wiring as it originally was.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-06-2012, 11:24 AM   #15
Rewards Points: 2,516
Is the receptacle in the same box as the switch? The wiring diagram attached will accompish what you want done which is receptacle always hot and the light switched.
Grounds are not shown for ease of drawing,
Electric outlet / light on same switch-sw-recep-lite.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
andrew79 (10-06-2012)
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 07:49 AM
Light controlled by switch, outlet always on, power at light...is this the way? pureevil Electrical 6 11-07-2010 06:32 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
adding outlet from light switch tad Electrical 17 06-06-2009 12:25 AM
