Electric Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2012, 07:08 AM   #1
Electric Outlet
Outlet stays charged even when the wall switch is off?
vivien60 is offline   Reply With Quote
Old 10-14-2012, 07:34 AM   #2
Rewards Points: 2,516
has outlet ever been controlled by said switch??
hammerlane is offline   Reply With Quote
Old 10-14-2012, 08:26 AM   #3
it is just been installed. Example for a fan. Think handyman did not connect the hot black from the outlet
to the switch wire that controls the 4 way bulbs vanity light? Maybe should be ganged together?
Old 10-14-2012, 09:18 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
How are you determing the outlet is hot? Voltmeter or one of those pen's that light up when it detects voltage?
Can you post a pic of the outlet and wires inside?
Old 10-14-2012, 09:29 AM   #5
custom user
Rewards Points: 150
It would help if you were a bit more concise. I thought you were talking about a wall receptacle to turn on a light but it seems you are referring to a bathroom vent fan and vanity lights. Why wouldn't the receptacle stay hot?
JasperST is offline   Reply With Quote
Old 10-14-2012, 10:05 AM   #6
Wall Outlet
It is just a 3 slotted wall outlet. You could put a electric fan, razor, lamp
or whatever. This outlet is always charged, even when you cut off at the wall
switch that controls the vanity lights above the vanity cabinet.
Old 10-14-2012, 10:07 AM   #7
so the outlet pictured above use to be able to be turned off by the switch that controls the vanity lights above the vanity cabinet, but now the outlet pictured above cannot be turned off by the switch that controls the vanity lights above the vanity cabinet.
Is this it?
Old 10-14-2012, 10:30 AM   #8
correctomundo
correctomundo
Old 10-14-2012, 12:31 PM   #9
Master Electrician
If this is your bathroom plug its all wrong to begin with. Secondly I don't see a point in having a switched receptacle in a washroom. He most likely did you a favour. Third you hired a handyman to do electrical work and while some know their stuff well most don't have a clue. It's a simple fix to get it switched again but would need pictures of the switch location wiring and the plug location wiring.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-14-2012, 02:42 PM   #10
Thanks for the help
Thanks all the folks for the help
Old 10-15-2012, 12:17 AM   #11
Master Electrician
Tell your handyman to come back and put a gfci plug there before someone gets hurt.
Old 10-15-2012, 06:50 AM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
No, get a real electrician in there instead of some hack handyman.
The Following 5 Users Say Thank You to Speedy Petey For This Useful Post:
andrew79 (10-15-2012), frenchelectrican (10-16-2012), jbfan (10-15-2012), jrclen (10-15-2012), stickboy1375 (10-16-2012)
Old 10-15-2012, 01:17 PM   #13
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Isn't this the way it is supposed to be?
I thought the main reason to have an outlet controlled by a switch was so you could plug in a lamp and turn a light on or off from the door way.
If your switch already controls a vanity light, there is no reason for it to control the outlet.
Old 10-15-2012, 06:22 PM   #14
Master Electrician
Not to mention the fact that because its in a washroom it should be gfci protected. Unless of course its a massive bathroom that just happens to have a plug outside the gfci clearance area.
Old 10-15-2012, 06:41 PM   #15
In the US there is no "clearance area".
The Following User Says Thank You to Speedy Petey For This Useful Post:
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 07:37 AM
electric outlet rafa7 Electrical 0 04-22-2011 08:07 AM
Covering an electric outlet with cabinets Georgejc Electrical 15 04-20-2011 11:52 PM
help! with electric outlet Brad325 Electrical 7 05-03-2009 12:01 AM
