Electric motor runs but lacks power.
The motor is from a portable cement mixer, second hand, so may not be the original motor, The motor is a Wagner Leland, type SP AKT6, Model F7 939NH. 1725 RPM, 115v, 5.0 Amp, Rating continous. It ran when I first got it but could not handle the load once I filled the Drum. The pulley ratio looks fine, I think the motor needs some new life. Questions, Should this size motor handle the job? If it should, what need to be done to regain the power? Should it be rebuilt or replaced?
If it is the wrong size, what is recommended?
