Electric Motor Cleaning - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 04:52 PM   #1
jburd964's Avatar
Rewards Points: 166
Electric Motor cleaning
I inadvertedily got blasting sand inside a 5 hp 220 electric motor. I don't think it's much, but would like to take it apart and clean. Whats the difficulty level? Would just blasting it out with compressed air be sufficient? Motors this size are pricey and would rather be safe then sorry.
jburd964 is offline   Reply With Quote
Old 09-18-2011, 07:16 PM   #2
joed's Avatar
Rewards Points: 11,992
The biggest issue would be if it got into the bearings.
Old 09-18-2011, 07:25 PM   #3
jburd964's Avatar
Rewards Points: 166
There's only one way to hide out. You don't think it could have impact to omature are windings.
Gun control isn't about guns, IT'S ABOUT CONTROL.
Old 09-18-2011, 10:45 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,120
One could assume that it has sealed bearings....or should.....
5 HP? Not that heavy.....take it off what ever it's hooked up to....give it a good shake to get any sand to fall out....if little to no sand falls out....your looking good...
Then just blow it out.....
Next...give the motor shaft a turn by hand.....you will know real quick if there is any sand in the wrong places......I would keep turning it by hand while giving it a good shake and roll....this will help to make sure sand falls out of all the little spots it likes to fall into.....
Next.....just run it....
You really don't want to be taking it apart.....
ddawg16 is online now   Reply With Quote
Old 09-19-2011, 03:41 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,892
Don't take it apart. It's pretty darn hard to do if you're not equipped like a motor shop. I'd just blow it out with air and use it. Keep an eye on it for awhile. The bearings are the real concern. If they got sand in them, they will fail almost immediately (a day or two?) and need replaced. The bearings are cheap, but the disassembly and re-assembly suck. You'd have to do the same labor to take it apart and clean it as you would to replace the bearings so there's no point doing it as preventive maintenance.
mpoulton is offline   Reply With Quote
Tags
cleaning , damage , electric motor problems , motor
Cost-Benefit for electric vs heat pump, do my calculations look sound? chazman113 HVAC 13 08-13-2010 04:37 PM
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 10:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
