Electric Motor/capacitor Hookup Help - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2011, 07:50 PM   #1
Rewards Points: 180
Electric motor/capacitor hookup help
I'm working on building a small waste oil burner to experiment with-its going to be a siphon type that utilizes compressed air to atomize the fuel through a nozzle. I bought a small compressor from a surplus house and it came with a wiring diagram showing two black wires (to 120V), one green wire (ground), and two blue wires which go to a capacitor which was included. Here is the motor:
Here is the capacitor:
You can see in the second picture that there are two contacts each with two prongs. I'm assuming that one blue wire goes to one set of contacts and the other goes to the other set? I just don't want to hook this thing up backwards because I'm afraid of blowing up the capacitor, motor, or both. Also, do I have to be careful handling the capacitor-I know that they can store quite a bit of power, but I don't know if this one is "full" or not. Any ideas?
Badfish740 is offline   Reply With Quote
Old 02-09-2011, 09:17 PM   #2
joed's Avatar
Rewards Points: 13,308
Each pair of prongs within the circle are two contacts to the same point. Hook the cap to one prong in each circle.
Old 02-09-2011, 09:18 PM   #3
If you look at the terminals you will see that the two are tied together on each set. In other words you only have two terminals but two connections for each. If you are worried about the cap just short the two terminals together with a screw driver to discharge the cap.
hayewe farm is offline   Reply With Quote
Old 02-10-2011, 07:55 AM   #4
Rewards Points: 180
That's what I figured, but I'm not that familiar with capacitors so I thought I'd check. Thanks!
Old 02-10-2011, 09:00 AM   #5
Experienced
Jackofall1's Avatar
If you are not familiar with capacitors, be warned, once plugged in, the capacitor holds a charge even when unplugged, always ground the capacitor to discharge before touching any of its connections!!!!
Mark
Old 02-10-2011, 09:46 AM   #6
Rewards Points: 506
Mark
Do you 'ground' it? Or do you connect (short) the terminals to release the charge?
jlmran is offline   Reply With Quote
Old 02-10-2011, 10:28 AM   #7
Experienced
Jackofall1's Avatar
Yes you short the terminals, symantic's, folks just jump right in to correct, love it.
Mark
Old 02-10-2011, 10:33 AM   #8
Rewards Points: 506
Mark
You never know when someone (not necessarily this OP) will take a capacitor and shove it into the dirt!!!
Old 02-10-2011, 10:37 AM   #9
Experienced
Jackofall1's Avatar
Well if it were wet dirt it would work
Old 02-10-2011, 11:17 AM   #10
Rewards Points: 180
LOL...If I was that clueless about electricity I wouldn't be trying to build my own waste oil burner Wiring, circuit breakers, GFCIs, switches, fuses, etc...I'm fine with, I just know enough about capacitors that they could be potentially dangerous if not handled correctly.
Old 02-10-2011, 11:27 AM   #11
Rewards Points: 506
You mean mud?
Old 02-10-2011, 11:44 AM   #12
Experienced
Jackofall1's Avatar
You mean mud?
Well wet dirt usually is mud, again those symantic's man you just can't miss an opportunity can ya.
Old 02-10-2011, 11:46 AM   #13
Rewards Points: 506
Old 02-10-2011, 11:58 AM   #14
Rewards Points: 1,646
symantics, perhaps semantics? Or, perhaps a virus is involved? I was a bit confused at first.
bob22 is offline   Reply With Quote
Old 02-10-2011, 12:01 PM   #15
Experienced
Jackofall1's Avatar
Yep you cot me, ah chew, or was it a spellin air.
Cost-Benefit for electric vs heat pump, do my calculations look sound? chazman113 HVAC 13 08-13-2010 03:37 PM
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 09:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
