Electric Meter - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 06:01 PM   #16
Electrical Contractor
kbsparky's Avatar
Originally Posted by Etisfo View Post
I didn't say that specific meter, I'm asking for one that WILL work with 120v.
I already posted the link. Scroll back a few ....
-KB
Old 09-28-2013, 10:36 PM   #17
Metering
You will need a 1S Meter this is rated for 120v then 4 Jaw meter socket the 2 top jaws are line side the bottom 2 are load side at 100a these style of meters were used on older homes that did need 240 volts..
SMTech is offline   Reply With Quote
Old 09-29-2013, 04:20 AM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 2,108
Why make it so complicated.....$90
http://www.ekmmetering.com/ekm-meter...FQnhQgodqBIAWQ
Old 09-29-2013, 11:05 AM   #19
Rewards Points: 380
all of the older 240 analog meters will work on 120 there accuracy will be off about a 1/2 kw i belive. also some of the digtals will work on 120, i know the CENTRON will. i hooked to my portable oil heater this past winter, with an old 1934 westinghouse CS meter. both were accurate. if ya want one with out a meter base the "A" base work well, they kinda have there own built in socket.
circuitman is offline   Reply With Quote
Drop Wire (From Weatherhead to Meter) roadman1977 Electrical 7 12-24-2011 11:35 AM
200 Amp or 400 Amp service Boontucky Electrical 37 07-24-2011 12:33 PM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 06:00 PM
Electric meter garyoutwest Electrical 1 10-02-2009 04:10 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
