Electric Meter - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 03:59 PM   #1
Electric meter
Hi, I want to install an electric meter (yes, like the one the main service uses) inside my home for a specific room, but it is only 120v.
Is it possible to get a standard 240v meter base + a meter, and only use one side of the meter/meter base?
Etisfo is offline   Reply With Quote
Old 09-15-2012, 04:09 PM   #2
Julius793's Avatar
Yes I don't think it's an issue shop around see what you can find
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-15-2012, 06:19 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
How were you planning on rewiring to connect the one room to this meter?
Coastal South Carolina
Old 09-15-2012, 06:37 PM   #4
Pure Genius
Rewards Points: 150
Get am emon dmon. Might cost you though
Dierte is offline   Reply With Quote
Old 09-15-2012, 06:46 PM   #5
Rewards Points: 13,446
My main question would be why?
Old 09-15-2012, 06:52 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
This is the answer because good luck finding a POCO style meter.
I'll also ask, WHY in the world would you need to meter one room?
Speedy Petey is online now   Reply With Quote
Old 09-15-2012, 07:58 PM   #7
Master Electrician
Rewards Points: 3,808
He's got to know his overhead for the grow room. How else can he know if he's turninng a profit.
brric is online now   Reply With Quote
Old 09-15-2012, 08:01 PM   #8
Pure Genius
Rewards Points: 150
Well at least hes looking at his costs and not just charging what the other dealers are because that is the "going rate"
Old 09-15-2012, 08:04 PM   #9
Missouri Bound's Avatar
Not that hard to find....always available on Ebay
CENTRON Electric 240v WATTHOUR House METER & NEW 100amp SOCKET + Adaptors | eB
Do you want it your way or the right way?
Old 09-15-2012, 08:20 PM   #10
Msradell's Avatar
Rewards Points: 170
Originally Posted by Missouri Bound View Post
Unfortunately the description directly states it will not work for 110v (should be 120). The only option would be to feed a sub panel with 240 and then pull the 120v off of that.
Msradell is offline   Reply With Quote
Old 09-15-2012, 08:42 PM   #11
Electrical Contractor
kbsparky's Avatar
Originally Posted by Speedy Petey View Post
This is the answer because good luck finding a POCO style meter....
A quick search on ebaY found this one:
-KB
Old 09-15-2012, 09:25 PM   #12
Licensed electrician
Rewards Points: 1,460
Are you trying to monitor one device or the circuit?
There are monitors like the TED 5000 or the Kill-a-watt plug in devices.
Old 09-16-2012, 03:41 AM   #13
I am actually looking for this. Will it work with just 120v?
Old 09-16-2012, 06:18 AM   #14
kbsparky's Avatar
Ummm ... NO .... from the listing:
THESE METERS CANNOT BE USED FOR 120V APPLICATIONS, SEE OUR OTHER AUCTIONS FOR 120V METERS
-KB
Old 09-16-2012, 07:01 AM   #15
I didn't say that specific meter, I'm asking for one that WILL work with 120v.
Drop Wire (From Weatherhead to Meter) roadman1977 Electrical 7 12-24-2011 11:35 AM
200 Amp or 400 Amp service Boontucky Electrical 37 07-24-2011 12:33 PM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 06:00 PM
Electric meter garyoutwest Electrical 1 10-02-2009 04:10 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
