Old 04-14-2008, 07:14 PM   #1
Question
Electric Line Under Ground
Last Fall I put a electric line from my house to my shed and now I would like to run a electric line to a bird bath, Can I hook into that electric line and run it to the bird bath? How would you make the connection onto that electric line since it is under ground? How do you do it safely? Or do I have to run a new line?
Crazy Legs is offline   Reply With Quote
Old 04-14-2008, 07:56 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
There will be NO easy way to tap into that line underground.
You need to come from either building with the new line.
Speedy Petey is online now   Reply With Quote
Old 04-14-2008, 09:32 PM   #3
Idiot Emeritus
As stated above, there's no easy way. It can be done, but the time and complexity involved make it completely impractical except in the most extreme situations. A new line will be much easier, quicker, and safer.
Rob
micromind is offline   Reply With Quote
Old 04-15-2008, 12:25 AM   #4
Moderator
Termite's Avatar
Very impractical. Plus, the connection between the old and the new lines would need to be accessible above ground in a weatherproof junction box. You're better off tapping the power off of the outbuilding or come out from the house where the circuit originates.
Old 04-15-2008, 05:27 AM   #5
I did not think that it would be possible to do it that way.
My next question is what gage of wire should I use from the house to the shed? It is 125 feet? I would be better off takeing the wire I have now and running it over to the bird bath for it is 10/3.
Old 04-15-2008, 10:16 AM   #6
Licensed Electrician
jrclen's Avatar
It is not impossible, just expensive and impractical.
As to the wire gage, you need to tell us the voltage and the load.
jrclen is offline   Reply With Quote
Old 04-15-2008, 10:17 AM   #7
How could you possibly run a line that's already buried from point a to point b somewhere else?
Dude, if you want advice you'd better learn how to communicate more effectively.
LawnGuyLandSparky is offline   Reply With Quote
Old 04-15-2008, 04:50 PM   #8
Is this some sort of bird jacuzzi spa?
Run a line from the house or the shed....whichever is closer. #10 wire is overkill....unless is a heated bath
WhatEVER you do, GFCI protect it.
220/221 is offline   Reply With Quote
Old 04-15-2008, 05:57 PM   #9
Why do you think I would want to run a line to the bird bath! Yes it would be heated in the Winter here in Ohio.
I am using the shed as a work shop. So wouldn't you want a heaver wire going to it to handle the load?
Old 04-15-2008, 11:07 PM   #10
jrclen's Avatar
Run a new wire to the bird bath from which ever building is closest to it.
The shop might need an upgrade if you have more load than you have circuit capacity.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
New sewer line, damp ground tripower Plumbing 2 09-28-2007 03:40 PM
Ground rod blues!!! ra_doliv Electrical 8 09-03-2007 12:48 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
