Electric Hot Water Heater Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2010, 11:22 AM   #1
Rewards Points: 79
Not sure if this should go in the plumbing section.
My electric water heater's tank is leaking and I'm looking for a replacement unit. Currently there is a 3000 Watt heater on a dedicated 20 amp circuit using 12 ga. wire.
I've been told that with today's code, water heaters of this size (37 gal, 3000+ watts) need a 30 amp circuit. I also read that heaters up to 3700 watt could be used on a 25 amp circuit with 12 ga. wire. but 25 amp breakers may not be available.
The 3000 watt heater we have is only just adequate for our needs and running a new service to this area of the house would be a pain.
All advice appreciated.
RalphPeters is offline   Reply With Quote
Old 05-01-2010, 11:35 AM   #2
Master Electrician
Rewards Points: 3,808
At 240 volts a 20 amp circuit could provide 4800 watts. However, since this is considered a continuous load the circuit is limited to 80% of the maximum. By my calculation that limits you to 3840 watts on a 12 gauge 240 volt water heater circuit.
brric is online now   Reply With Quote
Old 05-01-2010, 11:39 AM   #3
Rewards Points: 79
It would be nice if I could safely use a 3700 watt heater on this circuit.
Mfg. recommends 20 amp for 3000 watt and 25 amp 10 ga.for 4000 watt but doesn't specify for the 3700 they sell.
Old 05-01-2010, 11:43 AM   #4
Master Electrician
Just noticed you are in Canada. Perhaps some northern brethren have a better answer based on the Canadian regulations.
selecting an electric water heater reds_21 Appliances 7 05-23-2009 01:48 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Replacing a Water Heater with Electric One 2031pratt Plumbing 3 12-26-2008 09:17 AM
Electric water heater (no hot water) heaterissue Plumbing 8 08-29-2008 12:16 AM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 01:51 PM
