Originally Posted by adutelle
I have oil hot air heat , electric dryer, electric stove , also have a well pump(120 volts). It seems from what i have found these oil fired hot water heaters are expensive to replace
That should not be a issue to run a electric water heater at all but just plan it ahead if you install the water heater where you can not see the breaker box then put a local disconnect switch a simple A/C pull out switch will qualify for this.
Yeah I know oil fired water heaters are not cheap to replace but I have them in Wisconsin and in France it cheaper than electric due have very high heat recovery compared to straight electric water heater.
Most resdentail water heater useally required a 30 amp circuit with two pole breaker.
Merci.
Marc
