-   -   electric hot water heater (http://www.diychatroom.com/f18/electric-hot-water-heater-90492/)
adutelle 12-26-2010 09:17 PM
will a 150 amp service be enough to run a 50 gallon hot water heater and how many amps does one of these draw?
nap 12-26-2010 09:21 PM
that would depend on what the elements are rated at. A 4500 watt element (one of the larger, if not the largest standard element I can think of) draws 19 amps so you would run a 30 amp circuit.
if you will have problems with your 150 amp service depends on what else is on it. In a typical 1000-2000 sq ft house, you generally are not going to have to much on the service unless you have full electric heat. The only way to really tell is do a load calculation and accounting of the current uses.
adutelle 12-26-2010 09:25 PM
how do i do the load calculations and how do you check to make sure the loads are balanced
nap 12-26-2010 09:30 PM
You can't really balance a residential panel. The loads are not continuous enough. Just make sure you don't have all large single pole breakers on one leg or the other.
a load calculation is basically making a list of the load descriptions and the circuit. Unless you have some big loads, you shouldn't have any problem with a 150 amp service. I have a 100 amp service, electric water heater, electric dryer, 3 1/2 ton A/C, gas forced air heat and have never overloaded my service.
jbfan 12-26-2010 09:32 PM
http://www.electricalknowledge.com/SFDLoadCalc.asp
This will help.
Are you replacing a gas unit with an electric?
Are you cooking and heating with gas?
adutelle 12-26-2010 09:43 PM
Im thinking about replacing a 21 year old oil fired unit with an electric one
secutanudu 12-26-2010 10:11 PM
If you don't have electric heat, i can hardly see a problem.
BTW, hey neighbor! :P
adutelle 12-26-2010 10:20 PM
I have oil hot air heat , electric dryer, electric stove , also have a well pump(120 volts). It seems from what i have found these oil fired hot water heaters are expensive to replace
clashley 12-26-2010 10:31 PM
Assuming your 150A service is in good shape, you should be fine to use an electric WH. You'll need a dedicated 30A 240V circuit for the WH.
frenchelectrican 12-26-2010 10:32 PM
That should not be a issue to run a electric water heater at all but just plan it ahead if you install the water heater where you can not see the breaker box then put a local disconnect switch a simple A/C pull out switch will qualify for this.
Yeah I know oil fired water heaters are not cheap to replace but I have them in Wisconsin and in France it cheaper than electric due have very high heat recovery compared to straight electric water heater.
Most resdentail water heater useally required a 30 amp circuit with two pole breaker.
Merci.
Marc
