Old 01-22-2012, 10:52 PM   #1
Electric heating cables under concrete
I have 2 electric heating cable units under concrete at my cabin, The electrician tested and said one has a broken heating cable, but did not know where. Is there contractors with testing equipment to locate bad area, drill out concrete and repair cable? Any suggestions welcome
gkalinoski is offline   Reply With Quote
Old 01-22-2012, 11:23 PM   #2
Semi-Pro Electro-Geek
Unfortunately, heating cable is usually unrepairable. Especially in concrete. You would need to contact the manufacturer of the cable to find out for sure whether it can be field repaired or not.
mpoulton is offline   Reply With Quote
Old 01-22-2012, 11:36 PM   #3
" Euro " electrician
frenchelectrican's Avatar
I am with him as well due some of the heating cable can not be able repair on the feild.
Merci,
Marc
Pros Cons All Electric Home??? Property Virgin Electrical 29 03-06-2013 06:33 AM
Radiant heating over old concrete slab Christina Haag Flooring 1 01-14-2012 02:39 PM
Concrete slab heating ducts mopar383 HVAC 3 02-13-2011 07:08 PM
Gas vs. electric heating (comparing MCF to kWh) fetzer85 Off Topic 2 07-29-2010 04:18 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
