Electric Heater Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2013, 06:02 AM   #1
I have three electric heaters installed on the 1st floor. All three heaters are running off of 1 thermostat the heaters keep turning off an on not allowing the 1st floor to get warm. The heaters are as follows a 1500,1500 and 2000 watts. These heaters are not running using a relay is this OK? We are using 10/2 wire and a 30 circuit breaker. Does anyone have any suggestions?
doneta44 is offline   Reply With Quote
Old 01-24-2013, 06:10 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Sounds like a bad thermostat.
Old 01-24-2013, 06:16 AM   #3
Rewards Points: 50
Is this a new install? Did it work before and now doesn't?
daveb1 is offline   Reply With Quote
Old 01-24-2013, 08:18 AM   #4
Rewards Points: 1,548
Don't forget that the thermostat has a load limit (watts). If you exceed this then the thermostat will go bad quickly if not immediately.
Sometimes a two pole thermostat (two side by side load switches inside) is wired with one pole controlling some of the heaters and the other pole controlling some of the heaters. Normally a two pole thermostat is used for 240 volt heaters to switch both of the feed wires.
Do all of the heaters go on and off together?
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Flushing crud from an electric water heater GaryLoki Plumbing 5 12-17-2010 02:19 PM
should I switch from natural gas to electric water heater supermaxhd Plumbing 24 11-28-2010 12:11 PM
Another Keeprite Electric furnace problem lrad Electrical 0 10-18-2010 12:24 PM
strange electric problem in new house, hot ground! area123 Electrical 29 07-25-2010 11:29 AM
