Electric Heat For Breezeway - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2010, 12:01 PM   #1
Just call me Andrew
Rewards Points: 1,020
Electric Heat for breezeway
I have a breezeway that I plan to finish, sitting on a concrete slab.The roof is above the ceiling. It's 4 walls are as follows.
1. 7' - Front - exterior w/ door & window
2. 7' - Back - exterior w/ door & window
3. 14' - Left - unheated garage on other side
4. 14' - Right - brick wall with house on the other side
I plan to put r-19 on the walls, r-10 (at least) under the floor, and r-19 (at least) on the ceiling.
I do not want to heat this room all the time, so I don't want to run hot water heat. I was thinking an electric baseboard. What size would be appropriate for this space? And how pricey are they? I've never bought electric heaters before.
Not sure if I should ask here or in the HVAC forum.
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 03-02-2010, 03:26 PM   #2
Electrician
Rewards Points: 792
They usually say 10W per square foot
7x14x10=980
So a 1000W should do it, baseboards are rather cheap.
If there is a door opening and closeing alot maybe look at a force flow heater, this will heat the area up much quicker but will be noiser.
darren is offline   Reply With Quote
Old 03-02-2010, 06:12 PM   #3
Will one side face South ?
You could put in some large windows facing South & dark flooring/tile
The sun would heat up the space quite a bit if its done right
Old 03-02-2010, 07:37 PM   #4
Just call me Andrew
Yeah, the front side faces south...I was thinking dark tile, too.
Andrew
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Tiling over mosaic (1954) with electric radiant heat? ControlTech Flooring 2 02-04-2010 08:01 PM
Electric ceiling heat jason8640 Electrical 6 12-17-2009 11:17 AM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
heat pump VS electric air handler V Moe HVAC 1 06-30-2009 09:20 PM
