Electric/Gas Range Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 09:39 AM   #1
I have a 6 year old house that has an island cooktop. It was wired for an electric cooktop (4 wire 240V with a 40 amp breaker). However, a gas range was installed in the house when we bought it.
I just noticed that in the cabinet underneath the gas cooktop, we have two 20 amp receptacles. One is for the gas range and the other is on the end of the island for general use. The electrician who wired the house took one of the hot wires from the 240 circuit for one of the 120V receptacles and the other hot for the second 120V receptacle. Wiring to the recepticles themselves are 12 gauge.
Problem is, I still have a 40 amp breaker in the panel protecting all of this.
I am guessing I need to replace the 40 amp breaker with two 20 amp breakers in the panel but I'd like some thoughts from people who know more than I do.
I appreciate any help.
txrun is offline   Reply With Quote
Old 12-23-2009, 10:00 AM   #2
joed's Avatar
Rewards Points: 13,322
Yes you abolutley need to replace that breaker with 20 amps. If the receptacle is present for the stove it should be removed also.
Old 12-23-2009, 11:37 AM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by txrun View Post
i have a 6 year old house that has an island cooktop. It was wired for an electric cooktop (4 wire 240v with a 40 amp breaker). However, a gas range was installed in the house when we bought it.
I just noticed that in the cabinet underneath the gas cooktop, we have two 20 amp receptacles. One is for the gas range and the other is on the end of the island for general use. The electrician who wired the house took one of the hot wires from the 240 circuit for one of the 120v receptacles and the other hot for the second 120v receptacle. Wiring to the recepticles themselves are 12 gauge.
Problem is, i still have a 40 amp breaker in the panel protecting all of this.
I am guessing i need to replace the 40 amp breaker with two 20 amp breakers in the panel but i'd like some thoughts from people who know more than i do.
#12 = 20a
electures is offline   Reply With Quote
Old 12-23-2009, 08:25 PM   #4
1. Double check the neutral (white wire) connections where he tied into the original 240V circuit and make sure they are absolutely tight.
2. Install a 2 pole 20 amp breaker to replace the 2 pole 40.
220/221 is offline   Reply With Quote
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Electronic ignition question on propane range bearann Appliances 1 05-18-2008 09:11 AM
3 prong range? laduehelp Electrical 39 03-11-2008 01:33 PM
