Electric Furnace - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 09:29 PM   #1
Electric Furnace
Can I use Roomex #2/3wire to feed an 18KW electric furnace, putting it on a 100 Amp breaker. The furnace is staged and draws about 80 amps max under full operation. ( 240 V. ) I realize I don't need the neutral.
Sammy 2 is offline   Reply With Quote
Old 11-19-2011, 11:44 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,938
I didn't realize NM cable was available that large.
mpoulton is offline   Reply With Quote
Old 11-20-2011, 08:22 AM   #3
Electrician
Rewards Points: 794
Yes you can use #2, it is overkill but will work.
You could also use #3 wire.
darren is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Electric Furnace Alcarte General DIY Discussions 6 02-23-2011 07:13 AM
heat pump / ac unit vs electric furnace ellebt HVAC 4 01-12-2011 09:22 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
electric furnace need help Unregistered HVAC 3 10-16-2007 02:41 AM
