Electric Drier Outlet - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 04:46 PM   #31
I'm Your Huckleberry
Rewards Points: 2,270
Originally Posted by Speedy Petey View Post
I didn't me mean silly. I don't need friends to give me electrical advice.
Dyslexic much?
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Speedy Petey (11-02-2011)
Old 11-02-2011, 05:20 PM   #32
Licensed electrician
Rewards Points: 1,794
It is not illegal according to the National Electrical Code to install a 3 wire cord to fit the receptacle. This is so that new dryers can be used on wiring that was installed before the requirement for 4 wires.
Old 11-02-2011, 05:44 PM   #33
Older appliances used the 3 wire (no ground), but at the terminal block the neutral terminal had a bonding jumper that was attached to the grounding screw.
The tendency now is to run 3 wire plus ground for the circuit. In this case you would remove the bonding jumper, attach the neutral wire to the neutral terminal and attach the ground wire to the ground terminal (screw)
edge130 is offline   Reply With Quote
Old 11-02-2011, 06:22 PM   #34
Rewards Points: 120
Doc, one unwritten rule that I feel is always good to keep in mind is to think of the next guy. Seriously; you won't find it written as such in any code books, but that is one of the underlying goals, and what it some down to in certain cases. If you install a 3 wire cord on your dryer, you are operating within code, and it is obvious to the next guy that there is no ground, because there is only a 3 prong receptacle. While bonding within a 4 prong receptacle performs the same results from your aspect, the next guy would not know, by looking at the receptacle, that the ground is absent. There have been a couple of asides to this thread, and I don't mean to further confuse the matter, but only hope that this might help clear it up a bit.
Old 11-02-2011, 07:19 PM   #35
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
To Doc Holliday,
Why did you ask the question here if you are taking you best friends advice as gospel?
You are typical of posters who ask questions, do not like the correct answer and then do what you want regardless
Coastal South Carolina
Old 11-02-2011, 09:27 PM   #36
@ Doc,
It seems that you are going to take your friends advice regardless of the advice to the contrary posted by myself and others. Is this the case or have we misunderstood?
Old 11-02-2011, 09:46 PM   #37
Registered User
Rewards Points: 526
"Users shall treat each other with respect at all times on DIYChatroom.com. Name calling, personal attacks, or other inappropriate behavior will not be allowed and may cause your account to be banned." --- from the rules you all agreed to before, a reminder....
Gary
Old 11-02-2011, 11:47 PM   #38
Originally Posted by Jim Port View Post
@ Doc,
You might have missed the post where I said that I talked to him and he said to change the cord and keep compliant with NEC and then I followed with "and that's what I'll do." The only other thing passed on in that same post was that he said something about bonding it in the receptacle instead of in the appliance but that it was illegal. He did not tell me to literally do it nor did I ever mention again after that that I was going to, but that it was the same thing. I agree.
I literally read the section of NEC that Code05 posted to my bud over the phone and he said, "Yup, that's the legal way."
I don't see how anyone could think after all of the times I've said I was going to change the cord, thanks to Dexter, Code05 and my bud, as it's legal and the proper way that I'm going to now change the receptacle and bond it there or "ask and do not like the answer then do my own thing regardless. <angry face emoticon>"
Maybe I'm not the one who needs meds after all. Ha!
Thanks everyone, let's just let this die.
electric outlet rafa7 Electrical 0 04-22-2011 07:07 AM
Covering an electric outlet with cabinets Georgejc Electrical 15 04-20-2011 10:52 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
help! with electric outlet Brad325 Electrical 7 05-02-2009 11:01 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
