Electric Cord On Kitchen Garbage Disposal - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 09:08 PM   #16
Licensed electrician
Rewards Points: 1,622
Buy a new single pole switch.
Kill the power at the breaker panel. Test to make sure the unit does not work.
Remove the cover plate. Back out the 2 screws holding the switch to the box.
Remove the wires from the old switch and transfer to the new switch. Dress the wires and install the switch to the box. Replace cover plate.
Restore power and test.
Old 08-23-2012, 10:12 PM   #17
if the switch for the disposal is in a box with another switch there may be 2 circuits in the box, like for the light over the sink. it would be on a seperate breaker from the disposal so be careful or turn the breaker off that goes to whatever else is in the same box as the switch for the disposal.
Old 08-24-2012, 03:38 PM   #18
Sycamore Inn's Avatar
Rewards Points: 87
Ok switch replaced and the disposal works. Thanks Guys
Sycamore Inn is offline   Reply With Quote
The Following User Says Thank You to Sycamore Inn For This Useful Post:
oh'mike (08-24-2012)
Old 08-24-2012, 07:53 PM   #19
Rewards Points: 87
Ok the switch is replaced and the disposal works. Thanks Guys
garbage disposal wiring - hardwire question tpagel Electrical 18 06-19-2011 09:38 AM
Garbage Disposal Drains RickyBobby Plumbing 4 04-28-2010 07:08 AM
Working Garbage Disposal Required for Dishwasher benchmarkman Appliances 4 10-01-2009 07:50 AM
Garbage Disposal in the country? OffRoadAudio Plumbing 6 09-01-2009 04:19 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 12:23 AM
