Electric Cord On Kitchen Garbage Disposal - Electrical - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 05:12 PM   #1
Sycamore Inn's Avatar
Rewards Points: 87
Electric Cord on Kitchen Garbage Disposal
Hi,
I noticed the last few times I ran my kitchen disposal by turing off the electrical switch by the sink, the disposal/electric would run for a few minutes and then shut off.
Well today it would not shut off at all, I had to turn the breaker off and then unplug it. Monkeying around with it and trying the reset button on the bottom of the InSinkErator Badger 5 did nothing, it still constantly runs when I turn the breaker back on.
I looked at the outlet under the sink where the dishwasher and disposal plug in and tested the outlet with another appliance - coffee grinder - and it worked fine using the electrical switch by the sink it shut off and on correctly.
The Badger 5 rep on the phone said the disposal was manufactured in 2002. I then noticed when looking at disposal replacements the power cord is sold separately. Can I just replace the power cord? The blades are working fine.
I am not an electrician could I attempt this home repair myself??
Thanks,
Sycamore Inn
Sycamore Inn is offline   Reply With Quote
Old 08-23-2012, 05:23 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
There is no way a bad cord would make the disposal work with the switch off.
Old 08-23-2012, 05:24 PM   #3
Master Electrician
Rewards Points: 3,916
Originally Posted by Sycamore Inn View Post
Hi,
Replace the switch.
The Badger 5 rep on the phone said the disposal was manufactured in 2002. I then noticed when looking at disposal replacements the power cord it sold separately. Can I just replace the power cord? The blades are working fine.
Thanks,
Sycamore Inn
Replace the switch.
brric is online now   Reply With Quote
Old 08-23-2012, 05:33 PM   #4
Rewards Points: 87
Looking at the disposal again the cord may be part of the disposal - I'm not sure that it's separate.
Replace WHAT SWITCH? The electrical switch on the wall? The electrical switch works fine I just tested it again. Is there anyway to save money and just replace the electrical cord or does the entire disposal need replacement?
Old 08-23-2012, 05:42 PM   #5
Licensed electrician
Rewards Points: 1,744
Is this a half switched duplex receptacle? Perhaps the disposal was in the constant hot?
The cord is not the issue. The switch on the wall sounds like the problem.
Old 08-23-2012, 05:47 PM   #6
Rewards Points: 87
Garbage Disposal Won't Shut Off
Hi,
I looked at the outlet under the sink where the dishwasher and disposal plug in and tested the outlet with another appliance - coffee grinder - and it worked fine using the electrical switch by the sink it shut off and on correctly. The electrical appears to be working fine.
The Badger 5 rep on the phone said the disposal was manufactured in 2002. I then noticed when looking at disposal replacements the power cord is sold separately. Can I just replace the power cord? I'm not sure this cord is not part of the disposal. The blades are working fine.
I am not an electrician could I attempt this home repair myself?? Is there any way to save money and just replace the cord or does the entire disposal have to be replaced?
Thanks,
Sycamore Inn
Old 08-23-2012, 05:50 PM   #7
Rewards Points: 87
I'm confused. How can the switch be the problem when I plug in the vacuum and turn the wall switch on and off it works fine. The electrical wall socket is standard there are no buttons and I've switched the plugs from top to bottom and the disposal works the same.
Old 08-23-2012, 06:19 PM   #8
Master Electrician
Well its not possible for current to flow through an open working switch so you can rule that out. Wild guess is maybe that they switched the neutral and the disposal is somehow completing the circuit through the ground. It's almost a perfect storm scenario but it popped into my head so I figured I'd share.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
gregzoll (08-23-2012)
Old 08-23-2012, 06:28 PM   #9
Rewards Points: 87
Hmmmm. Soooo replacing the disposal will not solve my problem? Could the electrical component in the garbage disposal be the problem?
Old 08-23-2012, 06:41 PM   #10
The disposal cannot create electric on its own. The power must come through the switch. If the switch is hanging up internally the power will continue to flow and the disposal will remain on.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
brric (08-23-2012), gregzoll (08-23-2012), oh'mike (08-23-2012)
Old 08-23-2012, 06:57 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 774
The unit is 10 yrs. old. I'd replace the disposal altogether.
Old 08-23-2012, 08:47 PM   #12
I would try to change a $1 switch before changing out a $80 disposal.
Old 08-23-2012, 08:56 PM   #13
DIY staff
Rewards Points: 7,174
Have you used an electrical tester on the switch and outlet yet?
Old 08-23-2012, 08:58 PM   #14
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
This is not good advice...
Replacing the switch is...
Old 08-23-2012, 09:02 PM   #15
Rewards Points: 87
I don't have an electrical tester but I know someone who does.
Ok ...gotta love YouTube.
Ok the switch is replaced and the disposal works. Thanks guys!
garbage disposal wiring - hardwire question tpagel Electrical 18 06-19-2011 09:38 AM
Garbage Disposal Drains RickyBobby Plumbing 4 04-28-2010 07:08 AM
Working Garbage Disposal Required for Dishwasher benchmarkman Appliances 4 10-01-2009 07:50 AM
Garbage Disposal in the country? OffRoadAudio Plumbing 6 09-01-2009 04:19 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 12:23 AM
