Old 03-30-2008, 06:48 PM   #1
Electric Cooktop to Gas
Hey Guys ...
First post ~ need some help.
Just replaced my wife's electric cooktop with the a gas cooktop. Surprisingly, the conduit was only 3-wire (Black, Red and White). No ground wire. We built the home in 1992 (State of WA).
Needed to provide 110 to the new stove, for the pilot light. Obviously, used the white and black ...but, did not connect a ground wire. The plug for the stove and downdraft both have 3-prong plugs.
Is "no ground" wire a problem? If so, should I use the "red" wire (which is now unused) as a ground wire? Running a new wire would be a major under taking ~ i.e. lots of sheet rock between kitchen and panel (in garage).
We're trying to prepare our home to put on market, so want to ensure this is done right and poses no risk to future owners.
Thanks!
Kelly ....
spafford is offline   Reply With Quote
Old 03-30-2008, 11:04 PM   #2
Idiot Emeritus
The proper way to do this is to get into the panel, remove the 30, 40 or 50 amp two pole breaker , put a 20 amp single pole in one of the now empty slots, and land the black wire on it. The white should already be on the neutral bus. Put some green tape on the red wire, and land it on the ground bus. (If this is the main panel, not a subpanel, there's only one shared neutral/ground bus.)
Now, at the outlet, black is hot, white is neutral, and put more green tape on the red to make it the ground.
You now have an actual 20 amp circuit, just with oversize wire.
Rob
micromind is offline   Reply With Quote
Old 03-30-2008, 11:40 PM   #3
Thank you, Rob. That's exactly what I will do. Didn't think about the green tape. Was concerned I might cause someone some grief if they say the red wire connected to the common bus. The "green" tape seems like a rational solution.
Thanks a bunch,
Kelly ....
Old 03-31-2008, 06:43 AM   #4
When is fishing season?
CowboyAndy's Avatar
Originally Posted by spafford View Post
Hey Guys ...
Thanks!
Kelly ....
You mentioned conduit. It may be worth looking into and see if that conduit provides a ground path back to the panel.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
More On This Topic
If you have recently found that your kitchen is in need of a makeover, you might be looking at purchasing new appliances. If you have thought about replacing the cooktop in your kitchen, here are some helpful hints to know before going to the store. Read More »
Using a hammer, plug the extra oil dipstick hole, depending on which side of the block you don't want; learn how to do this correctly to prevent oil leaks in this free auto-remodeling video. Read More »
Removing Spark Plug Wires
Removing Spark Plug Wires by John Clarkson
Before removing spark plug wires, make sure the car is off to avoid shock. Remove spark plugs wires with auto repair tips in this free video on car maintenance. Read More »
Being a DJ is the dream of many people. Who wouldn't want the ability to control a large crowd of people with the music they play? If you're new to DJing however, all of the equipment needed and how it is all supposed to go together can seem a bit... Read More »
Help! Electric bill too high, what can I do? pirategirl007 Electrical 24 01-19-2009 11:35 AM
Electric cooktop vs. Gas cooktop Krichton General Discussion 5 06-16-2008 08:26 AM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 12:40 PM
need help with a new cooktop m_shel Electrical 9 02-08-2008 10:56 AM
electric oil boiler? for hot water? jamesdart Plumbing 2 01-13-2008 09:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
