Electric Circuit - Unusual Behavior - Electrical - DIY Chatroom Home Improvement Forum
Old 12-26-2013, 09:48 PM   #1
Hi;
I live in a house constructed in the mid-80s. I've mapped the circuits and know that the hall and master bath and master bedroom are on a single circuit.
The other day we noticed a funny smell from the master bath (my wife says fish, and I say crab). We flushed the drains with water and clog buster, and then placed and electric scent candle to freshen the air.
This morning my wife noticed that the candle was not on, and that the upper receptacle in the duplex was blackened. She removed the plug and the plug was burnt. Fortunately the circuit blew at the panel.
I replaced the duplex receptacle and trimmed wire about 3/4 inch past the burned wire. The new receptacle is in and the tester says the circuit is okay. Voltage is at about 124.6.
What is different is that the master bedroom lighted switches (one for the overhead light and one for the duplex receptacle on the adjacent wall) appear to be flickering.
Any thoughts about what may be going on with the circuit?
Thanks,
Corkster is offline   Reply With Quote
Old 12-26-2013, 11:59 PM   #2
Electrical Enthusiast
Rewards Points: 504
Sounds like you may have some loose connections. Are these receptacles "back -stabbed"? I.e. wires pushed into holes behind the receptacle instead of wrapped around the screws? I've seen that cause both the smell and the burning you describe.
I've seen many an illuminated switch flicker before. There's probably nothing wrong with that, but I will let some of the more knowledgeable members add their input.
Kyle_in_rure is offline   Reply With Quote
Old 12-27-2013, 06:04 AM   #3
DIY staff
Rewards Points: 7,174
Pull open the box and check all of the wire connections---flickering means arcing,usually---loose wire nut---bad wire---something is not right and will soon over heat. Do not ignore this---call in a pro if it is beyond your skills.--Mike----
Old 12-27-2013, 08:01 AM   #4
joed's Avatar
Rewards Points: 13,308
Those neon lighted switches do sometimes flicker as they get older.
The Following User Says Thank You to joed For This Useful Post:
Kyle_in_rure (12-27-2013)
Old 12-27-2013, 10:05 AM   #5
Thanks for all your input. I'll check the switch connections tonight.
Old 12-27-2013, 11:51 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 544
One thing I have found around here is the lack of use of wire nuts during that time.
All the neutrals and hots are crimped and then taped over.
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 09:45 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Rewiring older house WillK Electrical 12 10-13-2010 01:49 PM
Can 2 Electric Dryers plug into the same circuit or require individual 30 amp breakers? cooter1341 Appliances 5 06-22-2010 02:09 PM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
