Electric Ceiling Radiant Heat - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 08:49 PM   #1
Electric ceiling radiant heat
I'm remodelling a house, circa 1950, built when ceiling electric heat was subsidized by the power company. I expected to find some type of flex panel with heating coils between the joints.
Instead, I found one wire sandwiched between two layers of sheet rock on a portion of the ceiling that fell down. The wire is non-copper, probably nichrome or some other high resistance alloy. The insulation is labelled for Radiant heating and rated at 90oC. Each room has it's own thermostat and the system works well (where intact.)
I've not traced the wiring back to the circuit breakers. Is anyone familiar with this system? Can a single wire between joists truly be the only heat source? Does it run at 220 or 110 volts normally?
Viking
rjbacke is offline   Reply With Quote
Old 07-20-2010, 12:09 AM   #2
Journeyman Wireman
Rewards Points: 150
What little I've seen is 240v with copper or aluminum branch circuits to the thermostat. The heating wire is run to the ceiling and run back and forth on the wallboard and then coated with a plaster-like substance. Works fine until it doesn't. Usually due to someone putting a screw through the wire.
Jupe Blue is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Electric radiant heat energy costs? TomServo Flooring 11 04-20-2010 09:06 PM
Installing pex radiant floor heat, questions. iMisspell HVAC 27 01-15-2009 08:03 PM
Radiant heat question tpagel HVAC 4 05-21-2008 05:57 PM
porcelain tile over electric radiant heat aak3 Flooring 7 01-30-2008 09:33 AM
