Old 12-14-2009, 12:16 PM   #1
Electric ceiling heat
We recently purchaced a house built in 1977. The previous owner felt it was more important to have surround sound in the living room than heat. It is electric ceiling heat of some kind. It is 220. It has wires that run back and forth between two half inch sheets of sheetrock. Needless to say......when he installed the speakers in the ceiling he cut threw some of the wires. And now there is no heat in the living room. Can these wires be fixed? What kind of heat is it called? Any help would be appreciated. I have built three homes and never saw this kind of heat.
Thank you,
Jason
jason8640 is offline   Reply With Quote
Old 12-14-2009, 01:43 PM   #2
Remodeling Contractor
you need to know what type of radiant heat cables were used. Some are embedded with fine wires like ThermaRay panels, others are installed between two layers of drywall, mudding the cables in place to maintain a radiant barrier. Repair involves finding the break and reconnection the broken ends with a butt splice. An electrician will be able to find this area with many different tools. I find a tic tracer works well. The issue is that you do not cut into these panels without first marking where the wires are.
Old 12-14-2009, 03:12 PM   #3
An old Tradesmen
Moved to electrical forum.
Probably get more advise from here.
Old 12-17-2009, 10:17 AM   #4
Thanks for the reply. However I found the wires. They are a solid copper wire with insulation. I don't believe this type has panels. I think it is just wires ran back and forth. I do know that they are between two pieces of sheetrock. I also know that they are stapled to the top piece and covered by a second piece of sheetrock. Is it a certain type of wire? Because I know regular wire is rated to 105 degree's. Or will regular solid core wire work as long as it is the same gauge?
Thanks,
Jason
Old 12-17-2009, 12:01 PM   #5
An old Tradesmen
That ain't copper wire.
Copper wire wouldn't have much resistance and would blow the breaker.
It is a Special type of wire. And you can't just wire nut it together either.
Or you'll burn your house down.
They sell kits for splicing/repairing it.
Old 12-17-2009, 12:13 PM   #6
beenthere,
Do you know of a website where I can order these kits?
Old 12-17-2009, 12:17 PM   #7
An old Tradesmen
Afraid not.
I always got them from an electrical supply house.
Tags
electrical question, electrical wiring, hvac
heat pump VS electric air handler V Moe HVAC 1 06-30-2009 10:20 PM
advice on electric heat smartin114 HVAC 10 04-07-2009 11:43 AM
Heat vents near ceiling Cossack General Discussion 3 04-13-2008 09:31 AM
Add electric heat so suppliment fuel oil? arichard21 HVAC 12 01-13-2008 11:23 AM
Electric vs. Hydrolic Radiant Heat art2670 HVAC 2 08-23-2007 04:51 PM
