Electric Ceiling Heat - Electrical - DIY Chatroom Home Improvement Forum
Old 10-12-2009, 03:03 PM   #1
Our house was built around 1965. It has Electric Ceiling heat. Last year we noticed that the heat in the kitchen and the living room were not working. We have 2 bedrooms that are staying nice and warm. Can anyone advise what we need to do?
mommy21 is offline   Reply With Quote
Old 10-12-2009, 03:15 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the first thing would be to check if voltage is getting to the heating elements. Most ceiling heat I am familiar with use a line voltage thermostat. If yours does, that would allow you to check, at least one line (the heat could very well be 240 volt so there would be to supply lines) of the supply.
so, line voltage thermostat? If so, pull the cover off and use a voltmeter to check for voltage (to ground would be the best. You can end up reading 240 volts across the t-stat if it is not calling for heat and 0 volts if it is. can be confusing to a layman).
so, check that out and come back for more.
Old 10-12-2009, 07:26 PM   #3
Journeyman Wireman
Rewards Points: 150
I agree. Check that you are reading 240v. at the thermostat. If you are, check that you have 240v. at the load side terminals of the t-stat. If you don't, replace the t-stat. If you do have voltage at the load side of t-stat you probably have a problem within the ceiling wiring. Have you done any work on the ceiling in the last year? Or put a hook in the ceiling for a plant?
Jupe Blue is offline   Reply With Quote
heat pump VS electric air handler V Moe HVAC 1 06-30-2009 09:20 PM
advice on electric heat smartin114 HVAC 10 04-07-2009 10:43 AM
Heat vents near ceiling Cossack General DIY Discussions 3 04-13-2008 08:31 AM
Add electric heat so suppliment fuel oil? arichard21 HVAC 12 01-13-2008 10:23 AM
Electric vs. Hydrolic Radiant Heat art2670 HVAC 2 08-23-2007 03:51 PM
