Electric Cable To Detached Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 11:31 AM   #1
electric cable to detached garage
I'm running electric cable from the house to the garage. Is it against code to enter the garage with the cable next to a door?
bmorekid is offline   Reply With Quote
Old 12-31-2011, 11:55 AM   #2
MarginallyQualified
Rewards Points: 2,464
Underground? Aerial?
Assuming you're going underground... the conduit can stub up almost anywhere.
Without a diagram or pictures no one can be more specific.
The questions are with what comes after that: how and where you terminate the feed.
hth
Old 12-31-2011, 12:16 PM   #3
underground feed wire. I wanted to get as close to the subpanel on the wall as i can. the closest i can get is right next to a door. i'll probably enter in there. i would enter in on the same side of the wall where the panel is but in the way is a concrete sidewalk going to the garage door. thanks for your response
Old 12-31-2011, 12:20 PM   #4
MarginallyQualified
If the door hinges out... you should be fine.
If the open door will block access to the panel... not so much.
Old 12-31-2011, 01:31 PM   #5
Mad Scientist
I'm assuming you're bringing the cable out of the ground outside the garage, and then through a hole in the wall, yeah? If so, you should also run it through a short length of PVC conduit and an LB to protect it where it's exposed.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
bmorekid (12-31-2011)
Old 12-31-2011, 03:59 PM   #6
yes i will be. thanks for the help. i appreciate it.
changing location of electric service to the detached garage from the house. marlowc2 Electrical 3 06-13-2011 12:30 AM
Running electric to a detached garage xspader298 Electrical 4 03-21-2011 09:46 AM
Detached Garage sirsparksalot Electrical 16 10-18-2010 02:34 AM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 05:53 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
