Electric Cable Crossing (hot Water) Copper Pipe - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2008, 12:43 PM   #1
Rewards Points: 1,062
Question
electric cable crossing (hot water) copper pipe
i have a scenario in which a pair of water-supply pipes go parallel and in between beams in the ceiling while a couple of electric cables cross them perpendicularly and actually rest on those pipes rather than being above. i was just curious if this presents a hazard of some sort, e.g. can the hot pipe over time melt the insulation on the cable, causing current in the water supply etc. ?
thx,
- a -
Old 09-16-2008, 01:20 PM   #2
Does the insulation show any signs of heat damage? Modern NM-B cable is rated at 90 degrees Centigrade (194 degrees Fahrenheit), so it should be fine. Older NM cable was only rated at 60 degrees Centigrade, which should be OK unless the water heater thermostat is turned up very high. I would probably separate the cable from the hot water line or stuff a bit of insulation in between just to be on the safe side.
Matsukaze is offline   Reply With Quote
Old 09-16-2008, 03:52 PM   #3
i just did it so there would be no signs yet but was getting suspicious looking at it.
Old 09-17-2008, 01:49 PM   #4
Res Ipsa Loquitur
The foam-type snap on pipe insulation has worked well for me to keep something off a warm pipe- also helps keep the heat inside if done full length on the warm pipe.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 09-17-2008, 05:10 PM   #5
Registered User
Termite's Avatar
Your water plumbing and your insulated wiring can occupy the same space in nearly all cases without violating the code or creating any specific hazard.
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-16-2009 12:09 AM
Water pipe burst in basement bolivartech Plumbing 6 08-24-2008 02:11 PM
Electric Water Heater Problem mw2727 Plumbing 4 08-21-2008 02:51 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
