Old 03-02-2011, 11:04 AM   #1
Question
Electric Baseboard Wiring Question
Hi,
I'm finishing my basment and I'm wring electric baseboard heat. I will have a 8ft 2000Watt heater in 2 rooms, each room will have a thermostate.
Can I wire these in parallel so I can save a breaker space? Or do I need to have 2 fuses?
Thanks,
sonicdoom is offline   Reply With Quote
Old 03-02-2011, 11:29 AM   #2
Originally Posted by sonicdoom View Post
Hi,
Thanks,
I'm assuming this is a 240 volt heater? You will need at least two spaces in your panel regardless.
If it's 240 volts, and you want to put them on the same circuit, you'll need a 30 amp, 2 pole circuit with 10/2 wire.
DetroitEE is offline   Reply With Quote
The Following User Says Thank You to DetroitEE For This Useful Post:
sonicdoom (03-02-2011)
Range Wiring Question - Not Usual Question RWessner Electrical 5 12-04-2010 07:44 PM
Hydronic Heating (hot water baseboard) Question Midicat HVAC 7 10-06-2009 06:27 AM
Wiring Question bahaisamurai Electrical 3 02-22-2009 12:06 PM
Electric Baseboard Heater Problem goombie Electrical 9 12-23-2008 01:13 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
