-   -   Electric Baseboard Wiring Question (http://www.diychatroom.com/f18/electric-baseboard-wiring-question-97017/)
sonicdoom 03-02-2011 10:04 AM
Hi,
I'm finishing my basment and I'm wring electric baseboard heat. I will have a 8ft 2000Watt heater in 2 rooms, each room will have a thermostate.
Can I wire these in parallel so I can save a breaker space? Or do I need to have 2 fuses?
Thanks,
DetroitEE 03-02-2011 10:29 AM
Originally Posted by sonicdoom (Post 601009)
Hi,
Thanks,
I'm assuming this is a 240 volt heater? You will need at least two spaces in your panel regardless.
If it's 240 volts, and you want to put them on the same circuit, you'll need a 30 amp, 2 pole circuit with 10/2 wire.
