Electric Baseboard Wiring-Need Advice - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 04:51 PM   #1
DIY
Rewards Points: 39
I had 2 electric baseboard heaters in one room on a Honeywell T498B type in-line 220V thermostat. The wiring went from one baseboard, and then junctioned to the 2nd with a wire from the 1st. If I only hook up one and eliminate a baseboard and the junction wire between the first and second baseboard, will the thermostat still function as usual with just 1 baseboard?
From what I read in the manual I think, experienced chime in.
RocketManZ is offline   Reply With Quote
Old 01-31-2012, 05:10 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Yes you must turn the breaker off and make sure there is no power with a meter before you do anything.
You should be able to. There will be one set of wires going into the heater and one set going out. They will be one set that goes to the heater. You would have to disconnect both the wires going to the heater. Another option is install a thermostat on the heater itself. That's what I did on the ones I don't like to use all the time.
rrolleston is offline   Reply With Quote
Old 02-01-2012, 11:04 AM   #3
DIY
Rewards Points: 39
Breaker off and manually test with the meter every time, but good reminder.
Don't want to move the thermostat to the baseboard since I already have the box cut into the wall and the wires run, so i'll re-use it.
I needed to extend the location of the thermostat so I pulled the original BX style wire to the basement, put a metal junction box, and then used new 10 NM-B wire to go from the junction to the thermostat. Sound ideal?
Old 02-01-2012, 03:03 PM   #4
rrolleston's Avatar
Sounds good to me. Just be sure to use the proper connectors to secure the different type of wire to the boxes you use. Leave enough at each box so you can properly twist them together and wire nut them.
Old 02-01-2012, 04:59 PM   #5
Master Electrician
Rewards Points: 3,916
Is this extended circuit properly grounded?
brric is offline   Reply With Quote
Advice needed for Basement Wiring hazey313 Electrical 6 10-04-2010 11:02 PM
electric baseboard wiring toolbelt Tina Electrical 7 12-19-2009 03:48 AM
Wiring shop need advice stqevo Electrical 14 09-03-2009 12:18 PM
Electric wiring AMPIN88 Electrical 1 02-21-2009 10:31 PM
Electric Baseboard Heater Problem goombie Electrical 9 12-23-2008 12:13 AM
