Old 03-21-2012, 04:54 PM   #1
electric baseboard heaters
we have 2 baseboard heaters controlled by the same thermostat. the areas they are in used to be one room that has since been divided to add a bedroom. the other room is now the family room. needless to say, when we heat the family room, the bedroom is also getting heat and it's really not needed that much. how can we separate the two?
engraverlady is offline   Reply With Quote
Old 03-21-2012, 06:29 PM   #2
MarginallyQualified
That depends on how the wiring was done (and probably more importantly) how easy it will be get access into the wall to RE-FEED one or the other of the two BB heaters.
My guess is that the circuit from the panel goes to the thermostat and from there
it either splits off to the individual heaters (hope for this)...
or the power is "daisy chained" to the second heater (more likely).
A marginally qualified person should be able to open the junction box where the thermostat is mounted to see which you have.
hth
TarheelTerp is online now   Reply With Quote
The Following User Says Thank You to TarheelTerp For This Useful Post:
engraverlady (03-21-2012)
Old 03-21-2012, 07:09 PM   #3
i'll give a try. thanks
Old 03-22-2012, 10:28 PM   #4
I=E/R
a7ecorsair's Avatar
You didn't say if the existing thermostat is wall mounted or one mounted in one of the baseboard units.
a7ecorsair is offline   Reply With Quote
Old 03-23-2012, 02:47 AM   #5
Electrical Contractor
kbsparky's Avatar
Simply eliminate the wall thermostat, and install individual thermostats on the units themselves.
If one of the units already has a unit stat, then all you need to do is rewire the downstream wire to the line side, and install a separate `stat on the other unit.
-KB
Old 03-23-2012, 06:06 AM   #6
Licensed Electrician
k_buz's Avatar
^^^^ this would be the easiest
Double Pole Thermostat to Electric Baseboard jaredvallejo Electrical 4 01-18-2012 06:03 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
Different Load Baseboard Heaters in Parallel pankaek Electrical 4 03-25-2011 03:52 PM
One thermostat for two baseboard heaters wired this way GabrielB Electrical 4 12-23-2009 08:40 PM
Removing Baseboard Electric Heaters gieriscm Electrical 12 11-12-2007 05:59 PM
